2017-03-09, 10:46
Just unzip and copy whole folder pvr.iptvsimple to /home/osmc/.kodi/addons/
https://github.com/rkubera/pvr.iptvsimple/releases
(2017-03-09, 10:46)pan_klobouk Wrote: Just unzip and copy whole folder pvr.iptvsimple to /home/osmc/.kodi/addons/
(2017-03-10, 17:34)pan_klobouk Wrote: You have to connect via putty to osmc and install required packages:
sudo apt-get update
sudo apt-get install rtmpdump libav-tools
Next you have to set ffpmeg binary path to: /usr/bin/avconv
rtmpdump you have correct
(2017-03-18, 20:04)Philipp91 Wrote: I have the same problem as leisan, I can't find the finished recordings in the respective menu. The file in the recordings folder is created, though.
In addition, timeshift doesn't work for me (I press pause but nothing happens). Should that be working?
Lastly, I tried to compile the rkubera/pvr.iptvsimple repo for Windows, but it due to some weird Unicode stuff. See my post here http://forum.kodi.tv/showthread.php?tid=...pid2550900 if you can help.
(2017-03-25, 12:33)rkubera Wrote: Hi.
@leisan - recordings folder is not supported by this add-on. Find your recordings using "Videos" please.
For better quality add to recompression params for ffmpeg: -vcodec h264 or -vcodec libx264 please (you can check properly codecs using shell command:
ffmpeg -encoders)
Regards,
Radek.
(2017-03-25, 12:33)rkubera Wrote: @azh1000
Your log seems to be fine, but add-on not connected properly to source (bad address? stream cannot be viewed 2x in the same moment from the same ip? ). Check, if file size is increases during video recording. Recording will be deleted only if no data was received from the source.
Regards,
Radek.
