2015-09-10, 22:46
(This post was last modified: 2015-09-15, 03:29 by Ned Scott.)
Running an add-on like CinemaVision can truly enhance the KODI home theater experience, especially when it's set up to play your own personalized home theater intros and video bumpers. When a sequence/video begins, however, KODI often diminishes the theater feel with a "Please Wait" or progress bar that momentarily pops up. Would it be possible to add an option in KODI to either suppress or delay this portion of the OSD so that the user can define how long KODI should wait before the OSD pops up?
My Theater: JVC X790R + Peerless PRG-UNV | 120" CineWhite UHD-B Screen | KODI Omega + PreShow Experience | mpv | madVR RTX 2070S | Panasonic UB420 | Denon X3600H @ 5.2.4 | 4 x ADX Maximus w/ Dayton Audio SA230 | 3 x Totem Tribe LCR + Mission M30 Surrounds + SVS PC2000 + Monolith 15 | 40" HDTV w/ MeLE N5105 + MoviePosterApp | 40TB Win10 SMB Server over Gigabit Ethernet
That would be wonderful...
The add-on author provided a boolean condition for things like this, so why not use that?
Quote:Detect Running Status
This property returns a value of True if CinemaVision is running.
!IsEmpty(Window(Home).Property(script.cinemavision.running))
Just add <visible>IsEmpty(Window(Home).Property(script.cinemavision.running))</visible> to the DialogBusy.xml
Works for me.
Hey thanks Steveb for the suggestion. Where do I find the DialogBusy.xml? I'm accessing the RPi2 running OpenELEC via Samba but can't find it.
Gade
Team-Kodi Member
Hi MidnightWatcher.
I added the boolean condition for CinemaVision to the busy dialog.
When you get the next development update, please check if everything works as expected and that the busy dialog is hidden when using the CinemaVision add-on.
