wrxtasy I can confirm that we are working on GUI tearing issue for S8xx on OpenELEC.
2015-12-30, 03:55
(This post was last modified: 2015-12-30, 04:11 by hdmkv.)
Great, thanks. Will test and report back.
Update: Same results as w/previous build. 3D MVC MKV plays w/audio only, then even audio breaks apart and stops. 3D ISO doesn't play at all; causes Core to freeze. Thanks for trying however; I know you're flying blind w/o a 3D display to test on.
Curious if there's any Android box besides Zidoo X6/HiMedia H8 that have picked up Koying's MVC hack?
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
Koying
Retired Team-Kodi Member
Have you taken all the related patches from my master, and the ffmpeg patch from my fork?
It works on Android, and should work the same on OE.
2015-12-30, 09:21
(This post was last modified: 2015-12-30, 09:26 by Milkado.)
Any plan to launch the complete version with the patch? I'm afraid that I could no apply the update since I can not connect to my Openelc from my computer. I need to create a new image.
I just need to test the ethernet patch.
2015-12-30, 10:51
(This post was last modified: 2015-12-30, 10:52 by Milkado.)
Thank you, wrxtasy.
Can I replace those two files inserting my mSD in my Mac or PC (not Linux)?. I know that there are hidden partition in Openelec.
I would try it before asking but I have not an Openelec image right now.
PC or Mac, does not matter just replace the two files on the only directory that pops up when you insert the mSD.
Nothing tricky at all as its a Fat partition.
Reb313
Senior Member
Just got my Wetek Core. Great device. But decided to sell it and go with a Nvidia shield.
Only problem, is there are literally ZERO listed on Ebay or Amazon. Strange.
