  • 81
  • 82
  • 83(current)
  • 84
  • 85
  • 134
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)
@leeijo
according to Amlogic on S812 it will not work with all the receivers, I have an Onkyo at home and it works (with the framerate automation workaround on S812 for TrueHD and DTSHD)
Here you can find some tests.
http://mirrors.kodi.tv/test-builds/andro...mirrorlist <- here, handle with care.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
I put on my gloves to be extra careful Big Grin But it cannot be downloaded, no mirrors and the direct link returns 404 Tongue
then wait till it's there Smile
Read/follow the forum rules.
For troubleshooting and bug reporting, read this first
Interested in seeing some YouTube videos about Kodi? Go here and subscribe
(2016-02-06, 16:07)ChristianTroy Wrote: I put on my gloves to be extra careful Big Grin But it cannot be downloaded, no mirrors and the direct link returns 404 Tongue
Give it time :-)
Are you sure I thought it was 42 minutes and 35 seconds? :-)
Downloading Smile Switching again to the S905 to do the new test
Again only AC3/DTS in passthrough settings, I have not played the file this time because I guess that the HD audio passthrough setting has to be enabled.
http://pastebin.com/6EjadYA8
(2016-02-06, 16:11)fritsch Wrote: Are you sure I thought it was 42 minutes and 35 seconds? :-)
I tried it on my board (S905 wiht Lollipop) which doesn't seem to support HD Audio as now (maybe it need some edits to the OS as told by Wetek guys).
With this version even simple DD passthrough doesn't seem to work.
I get a very little noise, half sec or something like that at start and then only silence.
(note that with latest Kodi nightly i got 1-2 seconds of noise after starting a video and then simple DD passthrough works..)
(2016-02-06, 16:20)ChristianTroy Wrote: Again only AC3/DTS in passthrough settings, I have not played the file this time because I guess that the HD audio passthrough setting has to be enabled.
Found it, crap: https://github.com/fritsch/xbmc/commit/2...1a875a8802 :p damn amlogic incarnation.
No Debug Log, no issue, no problem.
(2016-02-06, 16:27)fritsch Wrote: No Debug Log, no issue, no problem.
Sorry Sad
LOG Here:
http://tempsend.com/9BAE8BA4FD
1) Started KODI and started playing file without passthrough
2) Enabled passthrough in the Audio options (noise and then silence..)
3) Disable passthrough in the Audio options
I turned ON and OFF passthrough in the "context" menu during video playback.
Same result changing from main settings.
EDIT:
With pp ON i had problems with video speed of playback and image corruption too
(2016-02-06, 15:48)ChristianTroy Wrote: @leeijo
Thanks for the reply Christian! Pcm multichannel works perfectly since last update anyways soo I guess it's not that important!
@runnerway Odroid C2?
Very much doubt it has the needed firmware patches, does it?
(2016-02-06, 17:20)Koying Wrote: @runnerway Odroid C2?
Yes. I've already said that it hasn't the needed patches in previous posts.
But as those commits will be merged in master i think they shouldn't break simple DD passthrough.
  • 81
  • 82
  • 83(current)
  • 84
  • 85
  • 134
  • 4 Vote(s) - 4.75 Average
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)4.754
