Yes I see, if you add back the original AudioFormat (those used by Amlogic) from koying patch would it work?
fritsch
Team-Kodi Developer
No, that's not the problem. They don't get enumerated. I think the the ctx does not get the AMLogic specifics via includes - I will test something.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
actually it makes sense, according to "aml_present" in AMLUtils there should be a log entry "AML device detected" but I can't find it
Is 3D Framepacking next on the MENU?
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
fritsch
Team-Kodi Developer
I tried with the Wetek Core on my Marantz.
DTS / AC3 fine
EAC3 / TrueHD / DTSHD - nothing.
CT or me in morning will test fritsch build just to verify if ok on our confirmed AVR's
fritsch
Team-Kodi Developer
@ The guy with the oodroid - could you please check with a "normal" nightly? To see if it stills works?
Thanks much.
