  • 82
  • 83
  • 84(current)
  • 85
  • 86
  • 134
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)
Ah right
I have issue with Kodi Jarvis RC3 and modified version of Wetek media player.
At the moment I have installed Play store Isengard and parallel Media player RC3. RC3 on playback change resolution to 1080p (my TV is 720p) and picture is shrunken. Kodi GUI is in normal resolution, only playback. On stop resolution returns to normal 720p. After more investigation it only affects HD content, SD is OK. But funny HD live streams (like BBC) are OK
I've played a little with settings and only if I "Adjust display refresh rate" turn off than is playback normal.
On Isengard I have this option set to "On start/stop", pause 1s and working OK.
Doesn't have such issues on OE Jarvis RC1.
I have Panasonic plasma TXP37X10 which is HD ready -1080i (720p).
log: http://goo.gl/ADBqfa
Any hint?
Thank you.
@ChristianTroy:
http://mirrors.kodi.tv/test-builds/andro...bi-v7a.apk <- I get -1 and -1 for the TrueHD / DTSHD support after querying, anything special I need to do to upgrade the wetek core?
What's your output with the above build (turn on debuglogging, restart)
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
To upgrade the WeTek Core just check for an online update on WeUpdate.
Installed that build, with debug log enabled this is the log (and still not HD passthrough options): http://pastebin.com/zpfewDqM
btw this test is on a S905 board but the AudioFormat devices are the same accross S8xx and S905 sources.
ps: with koying patch it is enumerated
pps: I tested the AC3 and DTS output (also DTS-HD, played as regular DTS "core") and it works here
edit: I think this else https://github.com/fritsch/xbmc/blob/b42...K.cpp#L783 does not let it go through the part where it should add them: https://github.com/fritsch/xbmc/blob/b42...K.cpp#L806
That's already fixed: https://github.com/fritsch/xbmc/commit/0...ea791e73c3 in the build you just tried.
Yes I see, if you add back the original AudioFormat (those used by Amlogic) from koying patch would it work?
No, that's not the problem. They don't get enumerated. I think the the ctx does not get the AMLogic specifics via includes - I will test something.
actually it makes sense, according to "aml_present" in AMLUtils there should be a log entry "AML device detected" but I can't find it
(2016-02-06, 19:42)ChristianTroy Wrote: actually it makes sense, according to "aml_present" in AMLUtils there should be a log entry "AML device detected" but I can't find it
Exactly and that's our issue currently - I test some foobar code to overwrite the other fields never the less, will find out. It's the next build - someone was so nice and cancelled the current one for me :-)
Big Grin thank you Smile
Is 3D Framepacking next on the MENU?
MY CURRENT MEDIA PLAYER | MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X  | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
I tried with the Wetek Core on my Marantz.
DTS / AC3 fine
EAC3 / TrueHD / DTSHD - nothing.
For HD audio tests, should we layman users still be testing w/the build Christian posted a few pages back w/the Core automation_kodi_permissions.zip patch? Thanks.
https://github.com/christiantroy/xbmc/re...aPlayer-v2
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
CT or me in morning will test fritsch build just to verify if ok on our confirmed AVR's
@ The guy with the oodroid - could you please check with a "normal" nightly? To see if it stills works?
Thanks much.
  • 82
  • 83
  • 84(current)
  • 85
  • 86
  • 134
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)4
