  • 85
  • 86
  • 87(current)
  • 88
  • 89
  • 134
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)
But it's already turned on in the one from the previous post, actually I never turned it off since when I started doing these tests the other day
One log with 16-rc3 and one with v17 is enough - playing EAC3 that is.
First decide what functions / features you expect from a system. Then decide for the hardware. Don't waste your money on crap.
Here they are (mediaplayer.log is rc3) https://mega.nz/#!pgQhRYyJ!Bs93-JM7D4LSD...mxC-xiL5gM
(2016-02-08, 16:16)ChristianTroy Wrote: Here they are (mediaplayer.log is rc3) https://mega.nz/#!pgQhRYyJ!Bs93-JM7D4LSD...mxC-xiL5gM
Found it (hopefully) - stay tuned for the next build :-)
Hi, sorry to jump in the middle of your work, but will your builds work on a Minix U1 at all? Currently getting very annoyed with the audio passthrough stutter!
(2016-02-08, 17:26)Boydford Wrote: Hi, sorry to jump in the middle of your work, but will your builds work on a Minix U1 at all? Currently getting very annoyed with the audio passthrough stutter!
"with the passthrough stutter"? What are you running? Stutter with these builds - no stutter with the other builds? This is a thread about Wetek Core, right?
I also tested latest build while waiting for new one. Again in first several minutes AVR loosing signal, just this time was more frequent than before.
Here is log with DTS-HD, TrueHD, DD+ from kodi-20160208-bcca99a-androidtestv3-armeabi-v7a build.
There was not a single change to the other formats, in lines: zero :-) Did DD+ work?
Edit: please use xbmclogs.com or something else - mega sucks as it is blocked here.
Yes, I used one DD+ test clip and my AVR locked signal so it played ok.
Hi, sorry I'm just skimming forums looking at the s905 development...I have a minix u1, which I notice a few posts back that someone was testing ur builds on. I was just interested if ur build, although for wetek would work.
@fritsch
kodi-20160208-76875b1-androidtestv3-armeabi-v7a.apk
AVR loosing signal frequently, and for longer period.
I notice that when playing file with TrueHD track AVR need more time to lock signal, but again same as with DTS-HD loosing lock each few seconds.
Log contain playback of files with DD+/DTS-HD/TrueHD
kodi.log here
So if you use the "older build" from that morning - it's much better (though EAC3 does not work, right)?
Well I think this one kodi-20160208-81ae87d-androidtestv3-armeabi-v7a.apk behave much better than latest ones. I can retest. Dunno why the version by CT dont have this issues with loosing signal at AVR?
A team colleague has run the code on those and it seemed to have worked ... currently building a new version: http://jenkins.kodi.tv/job/Android-ARM/7122/ give those a test, please. I think you need whatever newest firmware on the U1 available. Basically I want to write generic code - this amlogic special foobar is going on my nerves :-)
With the latest build I get a lock on DD+ but the audio is not played correctly, you hear micro fractions of audio playing, like constant stuttering, the signal lock is solid though, it's not losing it (always on 905 here)
http://www.mediafire.com/download/7tfwbc...0208-3.rar
edit: just to add a note that here on 905 all the other formats keep working fine
  • 85
  • 86
  • 87(current)
  • 88
  • 89
  • 134
  • 4 Vote(s) - 4.75 Average
WeTek Core (24p HD Netflix / HD Audio / Lollipop / OpenELEC / 4K / HEVC)4.754
