Can someone offer a comparison of the current WeTek CORE to the newly announced HUB? I know newer is always better but the price of the CORE is currently more expensive then the predicted price of the HUB - why? I was planning to buy the CORE in the next few days (if it comes out) but this has me second guessing.
2016-03-21, 21:30
(This post was last modified: 2016-03-21, 21:31 by grossbard.)
I have a core on order. Few questions.
1. Are there still plans to implement multichannel PCM in OpenELEC?
2. Is there a way to toggle full/limited range hdmi with this device?
2016-03-21, 23:16
(This post was last modified: 2016-03-21, 23:21 by grossbard.)
I mean can you adjust the color levels between RGB PC (0-255) and RGB TV (16-235) to achieve proper black and white levels on a monitor.
2016-03-22, 03:45
(This post was last modified: 2016-03-22, 03:46 by grossbard.)
That's kind of a bummer. My TV's HDMI inputs can either be set to full or limited range. The HDMI input that my AVR is connected to is set to full, because my PC and PS4 are connected to it. I prefer the PC to out put a full range RGB picture. I guess I could use a splittler wit the Core and run one HDMI cable to a limited range input on the TV and another HDMI cable to the AVR for audio.
2016-03-22, 08:36
(This post was last modified: 2016-03-22, 11:30 by HomerJau.)
Could someone please confirm the differences between:
Installing Kodi on a WETEK Core running Android
Installing Kodi on a WETEK Core with OpenELEC
I assume I'd loose Netflix if I go with OE?
Is there a comparison anywhere? Feature vs Feature etc?
I've got an OE Intel NUC. Looking for a second box for another room, share my audio/video library on a NAS.
2016-03-22, 11:29
(This post was last modified: 2016-03-22, 11:31 by HomerJau.)
Thanks for the feedback. I will probably try dual booting and check them both out.
For my second room it will be a stereo TV so no need for 5.1 (yet). Hopefully HD 5.1 will be supported moving forward. Did I read that Kodi 17 would solve that?
