Sorry if this was asked befoere but I want to know how is the performance of the ethernet at 1GB because im planning to relace my CuboxTV and im not sure if worth the trouble.
Hugh.
I have no idea about CuboxTV, but WeTek Core works great under Android OS or OpenELEC, and network streaming bandwidth is a non-issue w/either.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
I have just received my wetek core yesterday and when plugged in to tv via hdmi by the time i got to the mainscreen it freezed so i restarted it and the same thing. The third try it did not happen so i reseted it and looked for an update. The problem was gone for a lil bit. I installed kodi and all the addons i wanted and while playing some tv shows the screen turned black (it was not the tv) wetek was not responding for like almost a minute and then played back again, it happened twice. After that i switched to netflix app and the same thing. Is the tv size too much for the wetek core? I have a vizio m 4k 55" or any suggestion if i need to adjust something in the wetek? Or bad device?
Guys this Wetek Core have CEC funtion available?
So after a lot of research I finally bought this as my first android box. Getting delivered tomorrow. I've had a read through some of he thread but there is quite a lot here!
I just wondered if there are any out of the box essentials I need to know (firmware to download, settings to set) before starting to play around.
Many thanks!
Got my Core yesterday but it had Kodi 15.2 not 16 installed in Android, also no Australian/NZ power point adapter on the power supply. I can't install Kodi 16 on a spare SD card (32GB), fails to complete the Kodi install (however today I will leave it on with blank screen for a couple hours and see if it finishes). Anyway, I'm off to buy an 8GB card now, thinking 32 is not compatible...
I'm a bit surprised how slow the Core boots to Android off the NAND (Compared to an OpenElec NUC) and also that no Netflix app is pre-installed. Need to find that somewhere.
