2016-04-02, 22:48
Yes, as you know our upcoming products Hub, Play 2 and Play 2S are based on S905-H Revision C, and we already have OpenELEC supported there, as soon as products are soon out, we will push all code public.
(2016-04-02, 22:33)noggin Wrote: I like it even more now I've found that my USB RC6 IR receiver works out of the box with OpenElec. Using a remote control you're used to - and which has short cuts you like (subtitles, audio track switching, Live TV, codec details etc.) really does massively increase the usability for me. (I know for others it's not an issue)
(2016-04-03, 12:34)BoxFreak Wrote:(2016-04-02, 22:33)noggin Wrote: I like it even more now I've found that my USB RC6 IR receiver works out of the box with OpenElec. Using a remote control you're used to - and which has short cuts you like (subtitles, audio track switching, Live TV, codec details etc.) really does massively increase the usability for me. (I know for others it's not an issue)
Does this mean that for example same HP USB IR Receiver + Harmony One works out of the box (with minor tweaking with Keymap editor addon) as with OpenElec@Chromebox?
Quote:If so I will be very interested to test Core now that HD-Audio is also supported...
(2016-04-03, 13:44)BoxFreak Wrote: OK, I've misunderstood that HD Audio also works on OpenElec.
"Customised WeTek Jarvis 16.0 mediaplayer, based on Kodi Jarvis to allow for HD Audio + Kodi AMLogic specific bug fixes." I thought that means HD Audio under OpenElec.
(2016-04-05, 17:17)mwake Wrote: Hi can someone help me..I'm interested in this box for my mother but two key features I looking for is 24p TV switching capabilities and ability to pass through 5.1 audio?
(2016-04-06, 04:06)wrxtasy Wrote: WeTek Jarvis mediaplayer for Android is the preferred option if you want all the HD Audio or HD to lossless Multichannel Audio output features. SPMC I believe misses out on a few Core specific commits for Audio.
There are also other optimisations specific to the Core only, regarding Sleeping the box and some patches for playback of mpeg2 DVD's and Hardware decoding of mpeg4 content.
WeTek Jarvis 16.0rc3 mediaplayer HERE
This mediaplayer should also be packaged if you do an OTA Firmware update to v1.1.2 on the Core.
(2016-04-06, 04:50)aceisme Wrote:(2016-04-06, 04:06)wrxtasy Wrote: WeTek Jarvis mediaplayer for Android is the preferred option if you want all the HD Audio or HD to lossless Multichannel Audio output features. SPMC I believe misses out on a few Core specific commits for Audio.
I have the latest firmware on the Core. Is the Wetek Media Player under the app list?
(2016-04-05, 16:53)rich_sea Wrote: I've downloaded the "OpenELEC-WeTek_Play.arm-6.0.3" and put in on s SD card (Samsung Evo 64gb) using the Apple Pi program. That all seems to have worked fine but when trying to boot from it its just hanging on the menu screen where it asks to press power button to boot from sd card. Have tried pressing it at different times and different lengths of time but no change.
Have to unplug and boot back up with no card in and goes back to Android fine. Any ideas?
