ok tested 3d framepacking
Some did work , some not (in kodi)
issues with 3d framepack:
- Subtitles look too big and out of position
- Kodi gui looks oversized, not normal
- green thin line on top of screen
- audio out of sync
- quality could be improved
Some that didnt work
the croods , got stuck in beginning, audio played further , video got stuck on this:
Frozen started somewhere in the middle of the movie, audio wrong (multi ch stereo)
How to rain your drqagon 2 , wrong audio
again multi ch stereo instead of dts-hd ma 5.1
Then other stuff thats wrong
Some movies/tvshow gives artefacts
Heres 1 example of a serie that gave continuously artefacts
Mediainfo:
Volledige naam : \\UNRAID\Tvshows\Suits\Season 5\Suits S05 E01.mkv
Formaat : Matroska
Formaatversie : Version 4 / Version 2
Bestandsgrootte : 1,60 GiB
Duur : 42mn 7s
Totale bitrate : 5 454 Kbps
Datum codering : UTC 2015-06-29 19:31:39
Gebruikt programma : mkvmerge v6.3.0 ('You can't stop me!') built on Jun 27 2013 22:06:07
Gebruikte encoderbibliotheek : libebml v1.3.0 + libmatroska v1.4.0
Video
Formaat : AVC
Formaat/Info : Advanced Video Codec
Formaatprofiel :
[email protected]
Formaatinstellingen, CABAC : Ja
Formaatinstellingen, ReFrames : 4 frames
Codec-ID : V_MPEG4/ISO/AVC
Duur : 42mn 7s
Bitrate : 4 962 Kbps
Breedte : 1 920 pixels
Hoogte : 1 080 pixels
Beeldverhouding : 16:9
Frameratemodus : Constant
Framerate : 23,976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
Scansoort : Progressief
Bits/(Pixel*Frame) : 0.100
Stroomgrootte : 1,46 GiB (91%)
Taal : Engels
Default : Ja
Forced : Nee
colour_primaries : BT.709
transfer_characteristics : BT.709
matrix_coefficients : BT.709
colour_range : Limited
Audio
Formaat : AC-3
Formaat/Info : Audio Coding 3
Format_Settings_ModeExtension : CM (complete main)
Formaatinstellingen, Endianness : Big
Codec-ID : A_AC3
Duur : 42mn 7s
Bitrate-modus : Constant
Bitrate : 384 Kbps
Kanaal(en) : 6 kanalen
Kanaalposities : Front: L C R, Side: L R, LFE
Samplerate : 48,0 KHz
BitDepth/String : 16 bits
Stroomgrootte : 116 MiB (7%)
Taal : Engels
Default : Ja
Forced : Nee
Tekst #1
Formaat : UTF-8
Codec-ID : S_TEXT/UTF8
Codec-ID/Info : UTF-8 Plain Text
Titel : QoQ-Team
Taal : Nederlands
Default : Ja
Forced : Nee
Tekst #2
Formaat : UTF-8
Titel : CC
Taal : Engels
Default : Nee
Forced : Nee
Other big problem is 3d iso thats not played correctly in 2d if you want i can provide sample
