No option for desktop after exiting kodi
I'm currently on 15.1 having upgraded through different versions from an initial install of xbmcbuntu a couple years ago. After clicking power and then exit in Kodi I get a login prompt with only xbmc and "other" as options. Using either one has the same effect - kodi is started again. I want to drop to the desktop so I can set up a flirc that just arrived but I'm stuck. What do I need to do to add an option to login in to the desktop? Thanks!
Wink
The login process from XBMCBuntu to Kodibuntu has changed
Look at those screenshots and I think you'll find the desktop: http://kodi.wiki/view/Kodibuntu#Desktop_mode
That's what I've tried and there's no lubuntu option.
(2015-10-07, 16:17)kirkroy Wrote: That's what I've tried and there's no lubuntu option.
This thread may be relevant?
Could you get us a screenshot of what you see if you exit Kodi? Maybe do it with a smartphone and uploade the image on imgur for example.
No option for desktop after exiting kodi0
