Hi
I have Kodi 15.2 installed on my android box and I install hotstar addon when I click the hotstar icon . Error is show it say check the log . But the addon work fine on my iPad . Can you tell me how to fix it .
v_j_Uk
Junior Member
hi would you add tamil content?
2015-12-29, 06:08
(This post was last modified: 2015-12-29, 06:08 by activate.)
Hi yocoldrain, are you still working on the transition of the website ? Live sports is working but tv shows eg. aaj ki raat isn't. If that is the current state, thats fine. Thanks.
Macmini Server 2011 i7 Quad Core, OS 10.8.2, Amp Onkyo TX-SR308 USB WD drives 3x2TB TV Samsung Plasma 720p EyeTV Integration
There are only 10 kinds of people in this world, those who understand binary, and those who don't.
Hey Yocoldrain! Thanks for the wonderful addon!. I may have come across a bug, With the latest 1.0.5 update, if I configure the addon to "Let me choose" as the quality of the stream, then none of the options display actually "play", it seems to open it as a file and nothing happens. Can you please fix this in the next release?
can you tell me some that work on website for you, so we can try with indian ip and maybe some can try with VPN.
Thanks for much needed plugin for indian viewers.
I tried your plugin in my nexus 6. Its working very good. Much faster than hotstar itself.
But i really need this for my wetek box. Which is official partner of kodi and openelec. Its arm device aml8726MX with mali mp400 with dvb-s2 tuner. I have installed openelec in it and kodi Jarvis.
Everytime is try to install your plugin. It throughs error "cant install plugin".
Any chance of this working without Indian VPN ?
Hi yocoldrain
Now its installed on my openelec box.
Its working ok. But there is a big problem.
Its automatically stops after few seconds. If i restart the plugin or restart the link. Then playback stops at excactly same location as previously stopped. Its showing 0% buffer. And stays on that.
If i look in logs it reflects that plugin cant find stream.
I think its always stops where the hotstar throughs ads. And plugin dont find stream of ads and playback stops.
Thanks for the much awaited addon.
Please inform if TV Shows working for anyone in UK
Movies are working for me but not the TV shows, I am using indian ip in settings.
I am in UK
