I have a problem when i select a channel from the channel list. The channels work but only work randomly when selected. sometimes second time, sometimes seventh time i select them.
Does anyone know a fix to this problem
I do not. Just curious though which m3u playlist are you using and what kind of channels are trying to be streamed?
Keep looking through the threads though.
negge
yo guysv7may bd latr tomorroe
That's probably because the random stream you found on the internet is just that, a random stream on the internet that may or may not work.
