  • 6(current)
  • 7
  • 8
  • 146
  Thread Closed
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
#76
(2015-12-10, 15:22)popcornmix Wrote: Fernetmenta has produced a patch which has fixed most DVD menus.
There still seems to be another issue, but tonight's build will hopefully show an improvement.
That patch has fixed playback of my test DVD ISO.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
#77
(2015-12-10, 06:16)menakite Wrote: @popcornmix the problem with DivX files (lots of skipped frames, barely watchable) starts in #1208. Tested multiple files, so I guess you should be able to reproduce with a random one, but I can provide a sample if needed.
(2015-12-10, 08:19)MONSTA Wrote: The deinterlacing problem mainly on mpeg2. Heavy 1080/59i unwatchable with mmal decoding and mmal adv. Omx still good.
These are both the same issue. I think I have a fix pushed for tonight's build.
#78
ThanksYou for your joint efforts, popcornmix and Milhouse.
....will skip #1209 and have a look to your next #1210 nightbuilding ;-)
#79
Very nice! Appreciate the quick response. Have really been loving the advanced deinterlacing and auto slight overclock.
#80
i dont know how about you but for me on my original pi with 256mb for ram i have constant reboot this is log file (openelec is installed clean and almost stock)
http://pastebin.com/3HG2q9DD
video if problem
http://www.youtube.com/watch?v=zr0iIxVCYeg
#81
(2015-12-10, 23:33)Doktor-X Wrote: i dont know how about you but for me on my original pi with 256mb for ram i have constant reboot this is log file (openelec is installed clean and almost stock)
Might be a power supply issue. Does disabling overclock help?
#82
New OpenELEC K* build #1210: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.3.0 #1 Thu Dec 10 22:20:32 GMT 2015 armv6l GNU/Linux
# vcgencmd version
Dec  8 2015 14:44:44
Copyright (c) 2012 Broadcom
version e591b5eb05e2cdb1b5ae25512b27d33127d7bee9 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20151210221940-#1210-gc5875ae [Build #1210]
# vcdbg log msg 2>&1 | grep DTOK
001710.171: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (c5875ae6, changelog) and tip of XBMC master (079bac16, changelog) with the following modifications: Build Highlights:
  1. Use the sdhost MMC controller by default
  2. VideoPlayer updates - DVD ISO menu fixes, passthrough audio sync
Build Details:
  1. XBMC:
    • [linux] fix building on i386 (PR:8540, 1 commit, 1 file changed)
    • fix logging of failed dependency (PR:8527, 1 commit, 1 file changed)
    • cleanup lib/ (PR:8510, 1 commit, 3 files changed)
    • fix regression after PR #8362 (PR:8541, 1 commit, 1 file changed)
    • [PVR, json-rpc] Fix Input.Select for PVR fullscreen windows (PR:8533, 1 commit, 2 files changed)
    • FIX: [droid] app name parametrization (PR:8518, 2 commits, 9 files changed)
    • [pvr] allow file handling in kodi self, if add-on use also demuxing (PR:8544, 1 commit, 1 file changed)
    • Revert "[pvr] allow file handling in kodi self, if add-on use also demuxing" (PR:8548, 1 commit, 1 file changed)
    • fix rating scale for music in mediafilter (PR:8538, 1 commit, 1 file changed)
    • Addon enabled status fix (PR:8457, 4 commits, 6 files changed)
    • [PVR] Add option to hide disabled timers in timer window (trac #15914). (PR:8543, 1 commit, 8 files changed)
    • [strings] fix typos (77dfc879)
  2. pvr.vdr.vnsi:
    • replace colons in timer file names (PR:42, 2 commits, 2 files changed)
  3. newclock5:
    • New commits in this build:
      • VideoPlayer: fix for speed adjust of real-time streams (b0062d97)
      • VideoPlayer: simplify pausing of demuxer (d0e0f777)
      • AE: intermediate fix for sync of passthrough (96b13636)
      • VideoPlayer: adapt a/v sync to changing streams (7e605867)
      • squash: Only request a buffer when we have space. Sleep when we don't (9f0f1354)
      • VideoPlayer: finish old a/v stream before opening a new stream (638a79f9)
  4. kernel 4.3.y:
      • bcm270x_dt: Use the sdhost MMC controller by default (0a44e18f)
      • bcm2835-sdhost: Don't log timeout errors unless debug=1 (d17ef089)
    • Commits no longer in build:
      • Merge pull request #1178 from notro/multi2708 (ad3300ed)
      • fixup! Added hwmon/thermal driver for reporting core temperature. Thanks Dorian (906ab5c7)
  5. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [pkg] PR:8545: [mysql] Querying optimizer_switch needs to be non-fatal
#83
Confirmed, thanks.
Edit: Ah, I have also tested a H264+DTS just for fun. Everything looked okay, but looking at the (non-debug) log now I've spotted this error:
01:45:32 3951.759033 T:1506800544  NOTICE: running thread: CVideoPlayerAudio::Process()
01:45:32 3951.759033 T:1454363552  NOTICE: Opening stream: 2 source: 256
01:45:32 3951.760498 T:1506800544   ERROR: CAEStreamInfo::GetDuration - invalid stream type
01:45:32 3951.760742 T:1506800544  NOTICE: Creating audio stream (codec id: 86020, channels: 6, sample rate: 48000, pass-through)
#84
Advanced deinterlacing mpeg2 content is good again in 1210. Thanks!
#85
(2015-12-11, 01:18)Milhouse Wrote: New OpenELEC K* build #1210
#1210 play iso file have issues: ChapterOrBigStepForward / ChapterOrBigStepBack built-in function not work, system hangup.
#86
Good morning,
the first (fast) tests on DVD is perfect:
DVD menu works, bigin start with sound, Audio options are ok, hifiberry decode DTS fine.
"ChapterOrBigStepForward / ChapterOrBigStepBack" is ok on DVD.
Iso are playable, but "ChapterOrBigStepBack" is buffering longer time, but works (not so fine).
Thx - a great step forward :-)
#87
(2015-12-10, 18:00)popcornmix Wrote: I think I have a fix pushed for tonight's build.
Much much better, thanx, but still not perfect Smile
video for test https://drive.google.com/file/d/0B9_XmyO...sp=sharing
#88
(2015-12-11, 01:04)popcornmix Wrote: Might be a power supply issue. Does disabling overclock help?
I dont think its power suply since on same config kodi 16 runs fine without problem, infact one of the reasions why i installed 17 cleen was that after i updated from 16 to 17 i was facing same problem with reboot and then i revert to 16 and problem was gone
Ps
With or without overclock is the same
#89
Fast forwarding and rewinding mpeg2 liveTV with advanced deinterlacing enabled seems much more snappy!
Question... Does this "Use the sdhost MMC controller by default" mean that I can do something different in config.txt now if I want an overclock on the SD card? Currently I have:
dtoverlay=sdhost,overclock_50=84
#90
I think you still need that if you want to overclock the sdhost driver. Anyone loading the sdhost driver but without an overclock now doesn't need the "dtoverlay=sdhost" config.txt entry at all.
  • 6(current)
  • 7
  • 8
  • 146
  Thread Closed
  • 6 Vote(s) - 5 Average
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)56
