  • 43
  • 44
  • 45(current)
  • 46
  • 47
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-01-15, 11:30)it30rivers Wrote:
(2016-01-15, 10:07)Milhouse Wrote: Did you reconfigure the webserver port - the default is now port 8080.
It stayed as port 80 when I upgraded, which is why it opened the webpage off the bat, but I changed it to 8080 just to be sure. Still no difference. The Profiles, Movies, TV shows and Music tabs all sit there with the spinning loading circle, but the Remote tab works fine and controls the Pi properly, the whole time displaying the "connection to server lost" (I don't know if it's worth noting but my iphone app works 100% and loads the movie and TV show lists perfectly, so it's just the default webinterface that's broken).
The other web interfaces like WIMM work fine too via http://192.168.x.x:8080/addons/ (except AWXi since it seems to have disappeared off the repo and i need to reinstall it)
It's working for me with both 80 and 8080. I'd already changed my port to 8080 a long time ago, but the recent builds reset it back to 80 even though the default is meant to be 8080 (go figure). However both are working with no "connection to server lost" issues. I'd suggest renaming/removing your guisettings.xml and trying again, as something would seem to be screwed up.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-01-14, 13:31)popcornmix Wrote:
(2016-01-13, 22:40)mylle Wrote: No difference Sad
Could you produce a debug log (wiki) with "video" component specific debugging enabled with latest build.
Thanks you popcornmix. Sorry for the delay:
http://goo.gl/0itiS5
somehow I must lost this change last time I pushed to git: https://github.com/FernetMenta/xbmc/comm...7a799dab80
this should make your system recover from the issue originated in mediaportal backend. audio and video stream start with a huge offset of 800ms:
17:09:14 85.199478 T:1493136288 DEBUG: VideoPlayer::Sync - Audio - pts: 1032888.888889, cache: 251230.909482, totalcache: 449999.988079
17:09:14 85.199730 T:1493136288 DEBUG: VideoPlayer::Sync - Video - pts: 1809988.000000, cache: 50000.000000, totalcache: 100000.000000
(2016-01-11, 03:40)thosti Wrote: 0110b fixed that issue, thx! Blush
So, the newbie question: and now?
- Do I have to change something in my settings?
- Do I have to stay on 0110b?
- Do I have to report something on github/PR:7030 ?
Is your WOL still OK with build #0114?
#0114 is the first build for a long time (like #1001) with absolut great feature to play DVD's.
No stuttering Video on beginnig to play my Referenz-Test-DVD (Tina)
Thank You for this.
Harald
(2016-01-15, 19:41)FernetMenta Wrote: somehow I must lost this change last time I pushed to git: https://github.com/FernetMenta/xbmc/comm...7a799dab80
Thanks - will include in tonight's build.
You guys are amazing! Looking forward to try next build Smile
With 1114 resume playback from stopped position: time display start counting from 0:0:0
(2016-01-14, 20:33)build2die Wrote: Hi,
since a few builds (maybe #0110 or #0111) the 'in progress' view only shows 25 'in progress' tv shows. Show with new episodes will not show up, or other shows will be push out of the 'in progress' list.
I restored a know working database, but the behaviour is the same.
Is this a known problem, or might it be related to my setup?
Thx for the great work!
This is an intentional change in build #0111. I almost consider this as a regression.
I'm looking for a setting to increase the number of items in the In progress TV Shows list.
For recently added exists an advancedsetting parameter.
<videolibrary>
<recentlyaddeditems>50</recentlyaddeditems>
</videolibrary>
Can I modify the number of items in the In progress TV Shows list in a similar way?
<inprogressitems> did not work.
<videolibrary>
</videolibrary>
I realized that <recentlyaddeditems> also determines the number of items in the In Progress list.
Problem solved.
(2016-01-15, 22:34)envagyok Wrote: With 1114 resume playback from stopped position: time display start counting from 0:0:0
With 1114 :
Same problem for me with OMXPlayer : time display start counting from 0:0:0 after resume.
and with MMAL, only 1-2 FPS after resume playback.
With 1114 :
It seems to be an omxplayer only issue - doesn't happen with mmal. In #0112 there is an omxplayer fix so that it always shows the correct timestamp (it had been 2-3 seconds off), this might be responsible.
(2016-01-16, 00:08)vandamme Wrote: and with MMAL, only 1-2 FPS after resume playback.
Not seeing this behaviour myself, can you provide a debug log?
New OpenELEC Krypton build #0115: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.0 #1 Sat Jan 16 01:15:15 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Jan 15 2016 17:31:09
Copyright (c) 2012 Broadcom
version 50b1ff57f80db9c96b78757d2d2cfc226ed71f93 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160116011421-#0115-gaee4a3b [Build #0115]
# vcdbg log msg 2>&1 | grep DTOK
001733.412: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (aee4a3ba, changelog) and tip of XBMC master (7fe65f3a, changelog) with the following modifications: Build Highlights:
  1. New firmware
  2. OpenSSH: fix "roaming" security bug
  3. Stop disabling ARMv5TE and ARMv6T2 inline assembler (beneficial for HEVC cabac assembler optimisations)
  4. Move FFmpeg HEVC patches out of projects folder and into packages
  5. FFmpeg: bump 2.8.5-Jarvis-rc1
  6. PR:8871: JSON-RPC: make it possible to retrieve all seasons (independent of tvshows)
  7. PR:8872: videolibrary: support manually setting dateadded through NFO and JSON-RPC
Build Details:
  1. Firmware (Jan 15):
    • firmware: arm_loader: Accept arbitrarily large DTBs See: link
  2. OpenELEC:
    • make possible run Openelec as guest on KVM (PR:4622, 1 commit, 2 files changed)
    • Package updates (PR:4623, 4 commits, 4 files changed)
      • libevdev: update to libevdev-1.4.6
      • fuse: update to fuse-2.9.5
      • openssh: update to openssh-7.1p2
      • sqlite: update to sqlite-autoconf-3100100
    • Add a project for WeTek Core TV-box (PR:4626, 7 commits, 43 files changed)
    • ffmpeg: Stop disabling ARMv5TE and ARMv6T2 - needed by ASM optimisations (PR:4627, 1 commit, 1 file changed)
    • Update WeTek Play bootloader (PR:4628, 1 commit, 1 file changed)
  3. XBMC:
    • Videoplayer fixes and improvements (PR:8866, 7 commits, 8 files changed)
    • [filesystem/samba] - fixed uninitialised variable - rebase error duri… (PR:8867, 1 commit, 1 file changed)
    • rename MediaTypes helper class to CMediaTypes (PR:8861, 1 commit, 10 files changed)
    • [EPG] CGUIEPGGridContainer::UpdateItem: Fix m_item 'use after free' and invalid cursors, offsets. (PR:8848, 1 commit, 1 file changed)
    • [Win32] Fix for rotated videos. (PR:8810, 3 commits, 12 files changed)
    • [win32] cleanup VS solution (f4c1ba70)
  4. peripheral.joystick:
    • Analogstick fixes buttonmaps (PR:24, 2 commits, 5 files changed)
  5. pvr.mythtv:
    • 3.4.6 (PR:53, 2 commits, 8 files changed)
  6. newclock5:
    • New commits in this build:
      • VideoPlayer: optimze configure of renderer (ef9c643f)
      • VideoPlayer: drop unused members (bae54698)
      • VideoPlayer: improve av sync after stream changes (715d80ad)
      • VideoPlayer: fix drain for ffmpeg when filters are involved (aa149c8c)
      • VideoPlayer: fix detection of stalled audio (0695c430)
      • fixup! ffmpeg: Add cabac opimisations for hevc (8a5a2cb2)
    • Commits no longer in build:
      • VideoPlayer - pvr, set realtime flag for otherStreamHack (4c9b6c6d)
      • VideoPlayer: fix timeout of first configure of renderer (761c0326)
      • VideoPlayer: optimize locking in RenderManager (d01c7536)
      • VideoPlayer: fix usage of repeat picture (c1ee419f)
      • VideoPlayer: fix displayed a/v error on codec screen (ea7d2419)
      • VidoePlayer: fix incorrect counted drops (01ea75fd)
      • VideoPlayer: fix stalled state for audio player (f2414e73)
  7. kernel 4.4.y:
      • FIXUP BCM270X_DT: "random" (HWRNG) dtparam default is on (b0c9cd38)
  8. Additional commits/pull requests/changes not yet merged upstream:
    • Updated: [env] a70450cb: Intel: Implement Passthrough-Range
    • Updated: [env] cb39e8ec: VAAPI: Enable EGL
    • Updated: [env] fb950b85: Kodi: Use Limited Range by default
    • Updated: [env] fdddd9fc: xf86-video-intel: explicitely disable TearFree and TripleBuffer
    • Updated: [env] 865efc88: xf86-video-intel: bump to 371219c
    • Updated: [env] 091456e4: libass: bump to 0.13.1
    • Added: [env] 3f6ae7ec: FFmpeg: Bump to 2.8.5-Jarvis-rc1
    • Added: [env] patch: ffmpeg: Drop unpack()
    • Added: [pkg] PR:8871: JSON-RPC: make it possible to retrieve all seasons (independent of tvshows)
    • Added: [pkg] PR:8872: videolibrary: support manually setting dateadded through NFO and JSON-RPC
Kore is "Unable to connect to media center" in new builds.
The last working build is #0110
I see "Unable to connect to media center" in core when trying to update the library (swiping down from TV Shows, Movies, Music)
I can control Kodi using the arrows on the Kore touch screen, and I can play existing content from the Kore library, but can not update the library.
What caught my eye, was that inside Kore, TV shows were not being marked as watched, but they are inside Kodi. I also can not manually mark a show as watched from Kore.
All builds past #0110 exhibit this behavior including #0115.
(2016-01-16, 05:20)J_E_F_F Wrote: Kore is "Unable to connect to media center" in new builds.
http://forum.kodi.tv/showthread.php?tid=...pid2213488
  • 43
  • 44
  • 45(current)
  • 46
  • 47
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)6
