My first contribution.
Tried to play 3D isos for first time last night. There was a slight judder every few seconds (particularly noticeable on panning shots) that isn't present with 3D mkvs. So I tried a few things but eventually changed the adjust display rate setting from 'always' to 'on start/stop'.
This sorted the issue completely!
2016-01-31, 01:34
(This post was last modified: 2016-01-31, 01:40 by Mfleigle.)
Ever since build #122 "install from zip file" has been broken for me. No error shows up.
EDIT:
I found the cause:"requires xbmc.gui version 5.10.0 which is not available"
Is there anyway to disable the addon version check?
