2016-02-12, 04:28
Anyone else seeing no recordings when using pvr? I'm using pvr.mythtv. Reverted to 0210 and recordings show up again.
(2016-02-12, 05:00)Passaralho Wrote: No other skins than Confluente, or it's just me?
Even on Kodi repository there is no skin group under look and feel. Is it normal and will come back later on, or do I have something wrong going on?
(2016-02-12, 04:28)zaphod24 Wrote: Anyone else seeing no recordings when using pvr? I'm using pvr.mythtv. Reverted to 0210 and recordings show up again.
(2016-02-12, 10:17)Milhouse Wrote:(2016-02-12, 04:28)zaphod24 Wrote: Anyone else seeing no recordings when using pvr? I'm using pvr.mythtv. Reverted to 0210 and recordings show up again.
Can you upload a debug log from #0211? There's two PRs related to recordings in the last build, PR9105 and PR9112, but hopefully there's enough information in a debug lug to narrow it down. If nobody has any ideas I'll drop PR9112 from the next build.
(2016-02-12, 16:53)ksooo Wrote:(2016-02-12, 04:28)zaphod24 Wrote: Anyone else seeing no recordings when using pvr? I'm using pvr.mythtv. Reverted to 0210 and recordings show up again.
Makes it a difference if you toggle flattened view for recordings?
(2016-02-12, 17:06)zaphod24 Wrote:(2016-02-12, 16:53)ksooo Wrote:(2016-02-12, 04:28)zaphod24 Wrote: Anyone else seeing no recordings when using pvr? I'm using pvr.mythtv. Reverted to 0210 and recordings show up again.
Haven't seen that option before but I'll certainly set it and try tonight. Thanks!
(2016-02-12, 17:38)ksooo Wrote:(2016-02-12, 17:06)zaphod24 Wrote:(2016-02-12, 16:53)ksooo Wrote: Makes it a difference if you toggle flattened view for recordings?
Okay. The option imo is called "group recordings" and can be found in the Confluence sideblade of the recordings window.
