  • 71
  • 72
  • 73(current)
  • 74
  • 75
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
(2016-02-13, 10:48)ksooo Wrote:
(2016-02-13, 04:00)zaphod24 Wrote: Same here, folders exist again but no recordings in them and ungrouping also works (except I like them grouped).
Strange. Tested with tvheadend in the backend and it works just fine. Don't have MythTV but will see what I can do.
(2016-02-13, 04:00)zaphod24 Wrote: Another naggle is that if I am halfway down the channel list and then change to recordings, when going back to the channel list it starts at the top again. That has not always been the case.
Will look into this. Thanks for reporting.
Just another data point in case it helps:
Same problem of no entries in grouped Default recordings folder with build from kodi master with mythtv 0.28pre backend.
See debug log http://paste.ubuntu.com/15034758/
I know it is big try a search on "transporter"
Mike
@MikeB2013: Do I read this correct that you expect a folder "Default" and inside this another folder "Transporter" and inside the latter some recordings? And you do not have a toplevel folder called "DefaultTransporter", right? So, the problem is related to nested folders, I'd say. Tvheadend does not support nested folders. That's why I could not test this.
(2016-02-13, 12:58)ksooo Wrote: @MikeB2013: Do I read this correct that you expect a folder "Default" and inside this another folder "Transporter" and inside the latter some recordings? And you do not have a toplevel folder called "DefaultTransporter", right? So, the problem is related to nested folders, I'd say. Tvheadend does not support nested folders. That's why I could not test this.
Your reading is correct. There is no "DefaultTransporter" folder.
Top level Default (in this case), inside more folders (each of which has recordings),
Mike
(2016-02-13, 06:22)jarvismeier Wrote:
(2016-02-13, 02:59)Milhouse Wrote:
(2016-02-13, 02:53)jarvismeier Wrote: I'm still experiencing audio issues with the latest build.
Can you identify the first build with this problem?
The issue first appeared in build #0130b
There were quite a few possible changes there. Can you provide a sample file that shows the issue?
Cut a minute long sample (perhaps with mmg from mkvtoolnix).
If I leave audio output set to optimized or best dts-hd ma tracks are only sent as 2 channel pcm to my receiver. If I change the audio output to fixed, set channels to 7.1 then the full 7 or 5 channel set of pcm signals is sent to the receiver. I am using the kodi sample files for these tests, like the dredd 7.1 file.
Is this something everyone does or not typical, I hadn't tried fixed output until I noticed missing channels in playback.
Also pass through is not checked.
@Milhouse what is the status of Retro player inclusion?
Thank you! Ungrouping works for now.
The changes over the last year on the RPi2 have been amazing. 1080 advanced deinterlacing, ram overclocking and H265 playback. Thanks to everyone for the continued work on Kodi and the RPi/RPi2 platform!
(2016-02-13, 16:05)jvandenbroek Wrote: @Milhouse what is the status of Retro player inclusion?
Planned for the future, once Retroplayer supports Kodi 17 (currently supports Kodi 16).
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
(2016-02-13, 15:26)miker25 Wrote: If I leave audio output set to optimized or best dts-hd ma tracks are only sent as 2 channel pcm to my receiver. If I change the audio output to fixed, set channels to 7.1 then the full 7 or 5 channel set of pcm signals is sent to the receiver. I am using the kodi sample files for these tests, like the dredd 7.1 file.
Same behaviour i'm seeing. You should be able to leave it as optimized. My worry is that by setting it to fixed that it isn't actually reading the true multichannel track and is instead sending empty channels or up converting.
(2016-02-13, 17:44)jarvismeier Wrote: Same behaviour i'm seeing. You should be able to leave it as optimized. My worry is that by setting it to fixed that it isn't actually reading the true multichannel track and is instead sending empty channels or up converting.
Is omxplayer enabled or disabled?
Enabled.
I'm creating a 30 second sample file for you to check against. The MVC MKV is a straight extract from a 3D blurry ISO that was made using MakeMKV.
(2016-02-13, 17:58)jarvismeier Wrote: Enabled.
Can you check the behaviour with omxplayer disabled? If it only affects omxplayer, then that narrows things down.
If i disable OMXPlayer acceleration HD Audio is properly converted into multichannel PCM. I tested this using build #0130b.
Here is a sample clip you can test against https://dl.dropboxusercontent.com/u/1432310/sample.mkv
New OpenELEC Krypton build #0213: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.1 #1 Sat Feb 13 22:04:23 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Feb  9 2016 19:39:09
Copyright (c) 2012 Broadcom
version dc2c1aba32c7469e82a87be0d5d921aa9233e60d (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160213220329-#0213-ga9bb95e [Build #0213]
# vcdbg log msg 2>&1 | grep DTOK
001747.118: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (a9bb95e0, changelog) and tip of XBMC master (b86802e9, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest dcadec master (0e074384, ahead +139)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (cb923a2f, ahead +8)
  • Includes latest p8-platform master (38343e0a)
  • Includes latest addons: peripheral.joystick (6bf6821f, +43), pvr.argustv (9459a485, +9), pvr.demo (32952941, +8), pvr.dvblink (ff02fe16, +10), pvr.dvbviewer (d10f17c6, +7), pvr.filmon (76625cc8, +9), pvr.hdhomerun (f66cbe99, +8), pvr.hts (95b98abb, +45), pvr.iptvsimple (baaae159, +11), pvr.mediaportal.tvserver (39e89190, +33), pvr.mythtv (da0a6f50, +12), pvr.nextpvr (8c6e7ea7, +11), pvr.njoy (13bd96fd, +7), pvr.pctv (b321e302, +9), pvr.stalker (4da8913c, +10), pvr.vbox (83f95b9c, +15), pvr.vdr.vnsi (894555c6, +12), pvr.wmc (8327f887, +10)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 858f6461: xf86-video-intel: bump to 371219c
  • Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
  • Include [env] patch: Clean Kodi view cache on startup
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Fix RSS patch
  • Include [env] patch: Add experimental splash video
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] patch: kodi: peripheral.joystick binary addon
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] PR:7030: CNetwork - implement IPv6
  • Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8807: Controller input
  • Include [pkg] PR:8822: Implement ignore url options in CFileItemList
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:8923: [GUI] Replace thumb size with images res
  • Include [pkg] PR:8985: [gui] new infobool Window.Is()
  • Include [pkg] PR:9081: Fix limited songs query (for MySQL) and improve efficiency of GetSongs
  • Include [pkg] PR:9112: [confluence] [PVR] small adjustments
  • Revert [pkg] PR:7639: [IMX] fix - fb reconfiguration on resolution change while video playback (Reason: conflict with newclock5)
Build Highlights:
  1. Drop pvr.vuplus client - no official 4.2.0 support, no maintainer
Build Details:
  1. OpenELEC:
    • libass: update to libass-0.13.1 (PR:4708, 1 commit, 1 file changed)
  2. XBMC:
    • [cmake] CMake based buildsystem (PR:9083, 19 commits, 299 files changed)
    • Mrmc backports4 (PR:9062, 4 commits, 7 files changed)
    • [IMX] Add vsync ref clock (PR:7633, 1 commit, 4 files changed)
    • [IMX] fix - fb reconfiguration on resolution change while video playback (PR:7639, 8 commits, 6 files changed)
    • [Android] Fix cpu count on some Android devices (PR:9119, 1 commit, 3 files changed)
  3. newclock5:
    • New commits in this build:
      • rbp: Add zero copy interface to ffmpeg for software decode (76e3a36f)
    • Commits no longer in build:
      • fixup! rbp: Add zero copy interface to ffmpeg for software decode (a93db5ec)
      • MMALFFMPEG: Destroy the pool lazily (a7381e5c)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: Enable pvr addons, disable pvr updates
    • Reverted: [pkg] PR:7639: [IMX] fix - fb reconfiguration on resolution change while video playback (Reason: conflict with newclock5)
hi - i have no DD5.1 and DTS5.1 passtrough with this new build.
[Can not say anything about working last build, because i have some hardware rashes with my little server here - lost all my videos.]
EDIT:
i'm testing:
# 208 -> no DTS/DD
# 129 -> " " "
# 124 DTS/DD works - but chapter forward not
  • 71
  • 72
  • 73(current)
  • 74
  • 75
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)6
