  • 95
  • 96
  • 97(current)
  • 98
  • 99
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)
Great work Milhouse, that's fixed it! I hadn't realised sdhost had been replaced with sdtweak. Nice one!
(2016-03-05, 23:24)Milhouse Wrote:
(2016-03-05, 23:20)stevegal Wrote: using build 304 with the new estuary skin and I'm still getting the tv epg grid causing the infinite loop (pi2)
Still? Bummer.
Can you run the following command in ssh while it's in the infinite loop:
kill -SIGSEGV $(pidof kodi.bin)
then upload the crashlog file once Kodi has restarted - it may provide something useful.
Will do. Although it seems to be working now. Not sure the circumstances as to how the grid entered this loop, but I'll keep and eye out and if it happens again I'll post back.
(2016-03-05, 04:55)MarkT Wrote:
(2016-03-04, 16:41)pappaganush Wrote:
(2016-03-04, 09:34)opeters Wrote: That’s unfortunate. Can’t use another backend since only DVBLink works with my current AnySee tuners.
I could be out of place here but maybe this would be the time to switch to TVHeadend?
Good luck getting any vendor to support Kodi, not going to happen in 9 out of 10 cases imho. Just like Hifiberry, they all don't have a budget for it.
As for your problem, TVheadend will take a bit to learn, because it is a little over-engineered with regard to the channel lists. If you can spare
a few evenings of tinkering, it is very very powerful and flexible. Depending on the jurisdiction you are in, using it with oscam and e.g. a USB
smartcard reader might work and might even be legal. Don't discuss here though, use a search engine and a more appropriate site for CA.
Another option might be abandoning linear TV altogether and subscribe to a service like Netflix. There were times in my life when I watched
500 channels and after a couple of months it dawned on me that I wasn't really missing anything by not watching any of them.
Thanks for your comment. Just want to use the PVR for my default subscribed channels since it works and looks way better than on my 2015 Sony TV,
TVHeadend should support my USB Tuner's so I will give it a try then on the Pi3.
Shouldn't TVHeadend come with the OpenElec builds? Can't find the TVHeadend Backend in "Settings -> Add-ons -> Services -> tvheadend" as stated per Wiki ?
MY CURRENT MEDIA PLAYER
INTEL DN2820FYKH NUC 2D/3D WINDOWS
ACER HD9500BD / MARANTZ SR7009 ATMOS 7.1.4
TVHeadend is not included in the Milhouse builds, but they are available as addon:
http://milhouse.openelec.tv/builds/addons/
im an running TVHeadend with two sundtek usb tuners on a rpi_2
(2016-03-06, 02:34)Milhouse Wrote: Looks like dmesg didn't make it, however I think the problem is that you're using "dtoverlay=sdhost,overclock_50=100" in /flash/config.txt - try replacing "sdhost" with "sdtweak" and the WiFi (which operates over sdio) should then work.
Is that 'sdtweak vs sdhost" RP3 specific, or should I make that change for my RP2s?
(2016-03-06, 17:10)J_E_F_F Wrote: Is that 'sdtweak vs sdhost" RP3 specific, or should I make that change for my RP2s?
Should work on RPi0/RPi1/RPi2 as well.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Hi to everybody and thanks tor your great job!
just figured out my first problem with latest release. In some video´s the Codec information (button "o") appears automatically. Only a reboot helps. This issue hasn´t occurred with any releases before. Unfortunately my cec remote has no button to remove this window and for me the keymap editor addon does not work with the latest releases.
@ThonaV: Will be fixed in the next build.
Wow so quick response. Are you working day and nights? :-)
Thanks and best regards from Germany!!
(2016-03-06, 20:57)ThonaV Wrote: Wow so quick response. Are you working day and nights? :-)
He doesn't sleep at all Wink
(2016-03-06, 12:51)DerMarshal Wrote: TVHeadend is not included in the Milhouse builds, but they are available as addon:
Thanks. Seems straight forward and the Anysee E30 is recognized fine, added Ziggo ID:5555, MUX: 474MHz, Symbol Rate: 6875.
Unfortunately I am getting "DVB-C #0 - failed to tune [e=Invalid argument]".
Don't want to pollute this tread but if anyone can get me on track pls. PM me.
2016-03-06 21:39:03.421 [ NOTICE] START: HTS Tvheadend version 4.1-1577~g718d299 started, running as PID:464 UID:0 GID:39, CWD:/ CNF:/storage/.kodi/userdata/addon_data/service.multimedia.tvheadend
2016-03-06 21:39:03.422 [   INFO] mpegts: 474MHz in DVB-C network - tuning on Philips TDA10023 DVB-C : DVB-C #0
2016-03-06 21:39:03.422 [  ERROR] linuxdvb: Philips TDA10023 DVB-C : DVB-C #0 - failed to tune [e=Invalid argument]  Strange should be fixed: [url]https://tvheadend.org/issues/2807[/url]
2016-03-06 21:39:03.423 [  ALERT] settings: Unable to create dir "/storage/.kodi/userdata/addon_data/service.multimedia.tvheadend/dvr/config": Not a directory
(2016-03-06, 22:53)opeters Wrote: Don't want to pollute this tread but if anyone can get me on track pls. PM me.
tvheadend have a support sub-forum, try posting there: http://forum.kodi.tv/forumdisplay.php?fid=168
New OpenELEC Krypton build #0306: RPi / RPi2
(Supercedes previous build)
# uname -a
Linux rpi512 4.4.4 #1 Sun Mar 6 21:18:55 GMT 2016 armv6l GNU/Linux
# vcgencmd version
Mar  4 2016 17:58:52
Copyright (c) 2012 Broadcom
version 764f403f69e25e8a014c24f8a26f057960331205 (clean) (release)
# lsb_release
OpenELEC (Milhouse) - Version: devel-20160306211803-#0306-g8887975 [Build #0306]
# vcdbg log msg 2>&1 | grep DTOK
002481.999: Kernel trailer DTOK property says yes
# Kernel device tree status: Enabled
Based on tip of OpenELEC master (8887975e, changelog) and tip of XBMC master (5d6f7b87, changelog) with the following modifications:
  • Includes newclock5 patches
  • Excludes the OpenELEC linux-01-RPi_support patch in favour of sourcing these and possibly more recent patches directly from kernel branch rpi-4.4.y
  • Default setting for "Show RSS Feed" changed to disabled (new installs only) [patch details]
  • Disabled "Total Duration" in Confluence (see build #0221 for details)
  • Includes latest bcm2835-driver master (845eb064, ahead +1)
  • Includes latest dcadec master (0e074384, ahead +139)
  • Includes latest kodi-platform master (92583ef9, ahead +2)
  • Includes latest libcec master (6d68d212)
  • Includes latest libnfs master (eebe56ce, ahead +10)
  • Includes latest p8-platform master (38343e0a)
  • Includes latest addons: pvr.argustv (501f56b3, +21), pvr.demo (116a172a, +16), pvr.filmon (4beb05da, +23), pvr.hdhomerun (3f0dd8e6, +29), pvr.hts (0814da42, +55), pvr.iptvsimple (1dfc3547, +24), pvr.mediaportal.tvserver (4860e622, +48), pvr.mythtv (44df4430, +25), pvr.nextpvr (1871323c, +23), pvr.njoy (4f30f4af, +16), pvr.pctv (522f9603, +21), pvr.stalker (0402f465, +20), pvr.vbox (b0916449, +23), pvr.vdr.vnsi (2089549a, +21), pvr.vuplus (4cf6ad02, +19), pvr.wmc (9a83292f, +22)
  • Includes commits from service.openelec.settings/, ahead +1 (OpenELEC)
  • Include [env] e7cbe9cb: xf86-video-intel: explicitely disable TearFree and TripleBuffer
  • Include [env] ed774729: Intel: Implement Passthrough-Range
  • Include [env] 2f83a1cf: xf86-video-intel: bump to 8b8c9a36 (fixes segfault when refreshrate changing)
  • Include [env] 3a6268c9: VAAPI: Enable EGL
  • Include [env] 6f87cdbb: xf86-video-intel: bump to d167280
  • Include [env] 98c65e6a: Kodi: Use Limited Range by default
  • Include [env] 858f6461: xf86-video-intel: bump to 371219c
  • Include [env] compare: ffmpeg: Additional Jarvis 2.8.x patches
  • Include [env] patch: Enable other binary addons
  • Include [env] patch: Reinstate version check service add-on - avoid black screens on x86?
  • Include [env] patch: Fix kodi-send
  • Include [env] patch: Add extra headers needed by 3D BD MVC
  • Include [env] patch: Bump libbluray - include MVC support
  • Include [env] patch: Add experimental splash video
  • Include [env] patch: Enable pvr addons, disable pvr updates
  • Include [env] PR:4500: kodi: update to 17.0
  • Include [env] PR:4537: [scripts] Add PKG_SOURCE_NAME for non-standard package tarballs
  • Include [env] PR:4661: stripping changes
  • Revert [env] 46b9b7b3: rtmpdump (Reason: use newclock5 bump)
  • Include [pkg] PR:7030: CNetwork - implement IPv6
  • Include [pkg] PR:8254: FIX: Only handle 3D bitmap subs in TAB
  • Include [pkg] PR:8645: [video] Add season/TV show artwork to episodes/seasons even if they have their own fanart.
  • Include [pkg] PR:8723: Implement filecache retry logic
  • Include [pkg] PR:8824: videodb: fix smart playlists not honoring "Show empty TV shows" setting.
  • Include [pkg] PR:8922: [guiinfo] extend ranges for listitem properties
  • Include [pkg] PR:9225: Fix out of memory crash in CArchive
  • Include [pkg] PR:9287: [Estuary] - skin sync
Build Highlights:
  1. NOTE: DVD playback remains temporarily disabled
  2. Estuary updates (language, PVR)
  3. Second fix for EPG infinite loop
  4. Codec OSD fixes
Build Details:
  1. OpenELEC:
    • linux: patch to fix EDID parsing when ELD data spans multiple blocks (PR:4828, 1 commit, 1 file changed)
    • Package updates (PR:4832, 2 commits, 11 files changed)
      • Python: rename patches
      • mesa: update to mesa-11.2.0-rc2
  2. XBMC:
    • more libdvd fixups (PR:9270, 2 commits, 5 files changed)
    • [videoplayer][demuxer] Don't assume/force consecutive numbering of de… (PR:9247, 3 commits, 24 files changed)
    • adapt xbmc.vcxproj / filters to new addon include directory (PR:9274, 1 commit, 2 files changed)
    • Support has to return true if extension check was successfull and add… (PR:9275, 1 commit, 1 file changed)
    • [Estouchy] update (PR:9269, 1 commit, 143 files changed)
    • Merge settings dialogs xml's (PR:8856, 3 commits, 36 files changed)
    • Coverity - fixes (PR:9278, 2 commits, 2 files changed)
    • [osx] - remove DVDVideoCodecVDA.cpp for real - fixes unit tests (PR:9283, 1 commit, 1 file changed)
    • paplayer: fix detection of eof in passthrough mode (PR:9282, 1 commit, 1 file changed)
    • [EPG] Fix: Only notify observers for async epg event state changes, not for 'polled' events (PR:9281, 1 commit, 1 file changed)
    • [cmake] add InputStream (PR:9284, 1 commit, 2 files changed)
    • Implemented EnableStreamAtPTS to support enabling a separate stream w… (PR:9276, 1 commit, 11 files changed)
    • [lang][skin.estuary] automatic syntax corrections for the en_GB language file (5e7507e6)
    • [lang] updated language files from Transifex for Skin Estuary (5d6f7b87)
  3. newclock5:
    • New commits in this build:
      • VideoPlayer: drop cpu rel. usage from debug info (c73ceb27)
      • mvc: Automatically enable stereo mode (f5c94ab2)
      • fixup: Fix missing return value (7b7f75ca)
      • fixup! wip: fix playback multi-part titles (53ac36fa)
      • fixup: mvc build (8a2ea2e6)
      • codecoverlay: Include codec name in overlay (cc953937)
    • Commits no longer in build:
      • paplayer: fix detection of eof in passthrough mode (79c05393)
      • fixup! ffmpeg: use upstream mvc patches (9070593a)
      • fixup: Avoid seg-fault with null overlay (fc49e3c5)
      • MMAL: use common code for refcounting (12daa0ee)
  4. Additional commits/pull requests/changes not yet merged upstream:
    • Added: [env] patch: Fix kodi-send
    • Added: [pkg] PR:9287: [Estuary] - skin sync
How can you test to make sure sdtweak is working?
If I use dtovetlay=mmc I can grep Overclock with sdtweak I get nothing by grepping overclock
with build #0306 i get a strange problem with live-tv (vdr vnsi):
* on some scrambled channels i get no video, only audio is working
* unscrambled channels are working
* some scrambled channels work ok (ORF for example).
with build #0305: all is working ok.
debug log for #0306 where i switch from working channel to non working channel (DMAX HD) and back:
http://xbmclogs.com/pfzutjr7o
Max
  • 95
  • 96
  • 97(current)
  • 98
  • 99
  • 146
OpenELEC Testbuilds for RaspberryPi (Kodi 17.0)6
