Milhouse
Retired Team-Kodi Member
You can use tvheadend #0324 and continue updating to newer versions of OE - I'm pretty sure there's no relationship between the backend tvheadend add-on, and the front-end PVR API used by the various PVR clients.
Texture Cache Maintenance Utility: Preload your texture cache for optimal UI performance. Remotely manage media libraries. Purge unused artwork to free up space. Find missing media. Configurable QA check to highlight metadata issues. Aid in diagnosis of library and cache related problems.
Milhouse
Then you need to be more specific - when you talk about "the tvheadend client" are you referring to pvr.hts? If it's crashing kodi, you should have a crashlog - upload it and maybe the add-on maintainer will see it, or can be pinged once we know exactly which add-on you're referring to.
Although with all the add-on issues it's likely some other dependency that remains disabled and which is now bringing down kodi - the crashlog will reveal all.
Read note #4 in the first post for details on how to upload your crashlog.
Hi Milhouse
Happy Easter! ;-)
...a little question - why is DVD playback remains temporarily disabled so long time ?
Harald
advancedsettings.xml:
<splash>false</splash>
does nothing it seems. Still getting the splash screen, will try editing config file next.
btw how many splash screens do we need? I need 0. Although I currently have Openelec (1), animated Kodi (2), static Kody Krypton Logo (3), not counting the initial Rainbow splash screen...
@nuwonda: Hmm, that's odd. The entry in advancedsettings works fine for me. Except for the OpenELEC logo you can turn all the others off. Let me know if you need help with that.
Kind regards, Frank
Kodi: LibreELEC Beta
HTPC: Raspberry Pi 2 (Model B)
TV: Toshiba 47"
NAS: Debian Jessie x64 (Gigabyte GA-D510UD), HDD 3x1.5 TB + 1x2 TB (SnapRAID, MergerFS)
