holgip
Junior Member
Okay, I don't know that. I've tried your solution, but it doesn't work. I think I would post it in the german Kodi forum, also my suggestion with the touch-screen controls.
Thanks anyway for your answer.
I just upgraded to Jarvis 16.1. When I attempt to upgrade Transparency, it downloads the update then the screen immediately goes to complete black. No escape other than to restart Windows (Win 10 x64). When I check the skin Transparency has not been updated.
All of my set fanart has disappeared and I'm thinking of rolling back to Isengard. Any ideas how to fix this?
This was not a temporary thing. The PC became unusable after that. I had KODI set to launch immediately after Windows loaded, thus it blanked the screen in an unusable state. Using TeamViewer I was able to reduce KODI to a window. I then rolled back KODI to Isengard to get it to work.
Will Transparency 9 work under Isengard? If it does I can install it first and then try the KODI upgrade.
I'll give it another try in a day or two. Thanks.
After reverting back to 16.1 from Krypton Alpha 2 I get a message "The dependency on xbmc.python 2.25.0 could not be satisfied" when I try to install Transparency again. You have some advice?
2016-07-06, 01:09
(This post was last modified: 2016-07-06, 01:11 by DarkHelmet.)
What should I be logging exactly so you can look? A failed attempt of installing T!?
Edit for case of selective reading. Where should I look and for what, not you?
Thanks for the hint. It was two scripts. Globalsearch and image-research.select. I deleted these and could install transparency again.
Is there a way to reduce the home menu back to the size it was on the previous version?
Yay. Got it. Thanks so much!
