logi85
Senior Member
Snicket:
please update to 0.3.1 and make shure you've enabled debug in settings.
then start playing an item again from flix2kodi and post log.
p.s.: you can disable debug logging in kodi. It is enough to enable the debug in flix2kodi setting.
logi85
Senior Member
2015-12-31, 14:53
(This post was last modified: 2015-12-31, 15:28 by logi85.)
Yes it is.
Options -> Settings -> Addons -> Install from Repository -> select Logi85 Addons -> context menu -> search for updates
Edit: Did a little mistake, please enable kodi debug before trying.
Heya,
Great job mate!
How this would work on OpenElec?
~Home
2015-12-31, 16:04
(This post was last modified: 2015-12-31, 16:33 by Cassiuss.)
Thanks logi, for sending a reply! no 4. is my only issue at the moment.. I first used the MCE remote addon, but that didn't work. Like you said, Chrome is, of course, the active window. So I need to find a way to send a ctrl-w command with my MCE remote to windows... I have tried "LM remote keymap", but no matter which remote control I choose (mine is not on the list), so far no luck.. (I tried to change 8 to ^w, to make sure I would press the right button)
Anyone else on windows with any tips??
edit: one solution is to use the KODI remote app on my phone. If i press "back" there, it does go back to KODI.. Would like it to work with my MCE remote. When I found a solution, I'll post it here.
What would be necessary to get this fork work on an Nvidia Shield [Android] TV?
does this addon streams hd content?
It appears chrome launcher is working for me but after some research I found chrome to only support 720p and I thought I would try getting IE to work in launchbrowser.com, since it supposedly supports 1080p, and I was successful to a point. Everything was as it should be except the remote key mapping for some reason. the logitech remote is configured for WMC remote and work like it always been with chrome but not for IE 11. Wondering if anyone know how I should map the controller for Flix2Kodi hopefully with out breaking the remotes other functions for the Windows 8.1 x64 desktop. I am willing to try it on an alternate browser if it too supports both 1080p and WMC functions. Until then I went back to defaults settings on a perfectly working chrome/netflix setup with Flix2Kodi (...at 720p)
logi85
Senior Member
I will add support for other browsers. Please post the default path and parameters for each browser (Firefox, Internet Explorer, edge). I Also Need the window name of the browser while playing a video.
2016-01-01, 04:36
(This post was last modified: 2016-01-01, 05:02 by newsilentsilver.)
Problem in OpenElec with v0.3.1: video and audio are working fine, but the remote keys are not working anymore. In last plugin.video.netflix version (v0.1) they worked fine ...
Edit: Same problem of v0.3.1 if you add e. g. a movie to database and start from there (v0.1).
