2016-01-07, 15:18
(2016-01-07, 15:11)wyild1 Wrote:(2016-01-07, 10:31)grebus Wrote:Ok well for the sake of argument...the problem episode, could u unrar it and play it over ftp and see if that resolves your issue? Maybe there is a problem with the rar files..(2016-01-06, 14:48)Prof Yaffle Wrote: So, you're using FTP to the RAR archive of multiple episodes, and that gives you the "Buffering...." message - but navigating to an unrar-ed version and playing the AVI (over SMB/NFS or FTP?) works okay?
If that's the case, I'd immediately point a finger at having to FTP the whole RAR locally so it can be unrar-ed and then the file played... even if FTP allows some progressive playing (e.g. start playing while it's still downloading) for a normal file, I can't see that this would work on an archive, which may well need to be complete before it can be opened.
You've got it wrong. All other shows works rared. I never unrar...
None of them worked and when I locally unrared on my PC and then unrared and played again it worked. Isn't that strange?
