2013-11-23, 23:07
(2013-11-23, 22:12)swetoast Wrote: Probably been discussed before but the STV channels stutter under openelec rpi any solution for that ?
Try lowering the stream bitrate via de XOT add-on settings.
(2013-11-23, 23:18)swetoast Wrote: Tnx Basje that sorted my issue now its just a matter of finding the perfect bitrate before stuttering occors
(2013-11-23, 20:38)Basje Wrote:(2013-11-23, 01:41)Sleuteltje Wrote:(2013-11-19, 14:25)Basje Wrote: I managed to fix the length issue. I will create a pull request for the XBMC team and see what they have to say about my changes.
EDIT: https://github.com/xbmc/xbmc/pull/3683
Sorry for the late reply, have been really busy lately.
But awesome! Really great that you took the time to look into the issue! Is there a way i can have that in my XBMC now ? Or do i have to wait for the next version of XBMC or something (if the XBMC team likes it aswell)?
There is quite some discussion about the pull request. I merely made a fix to address your problem. But apparently the actual issue (the way it all works at the moment) is not ideal. So I don't know if they will accept the pull request. But I am working on it. Are you able to compile XBMC yourself? If so, then you can compile a custom version with my fix in it.
(2013-11-26, 22:37)Peppin Wrote: Hi Bas,
After updating to version 3.4 the Uitzendingemist streams (both mobile and regular) stopped working...stuck in buffering. Tried all sort of different settings.
Thanks..
(2013-11-26, 22:41)Basje Wrote:Sorry, I tried various max bandwidth plus streaming and cached play.(2013-11-26, 22:37)Peppin Wrote: Hi Bas,
Thanks..
You really need to tell a bit more. Please upload a xot(plugin).log to pastebin.com and post the link here. Also tell me what settings you have tried?
EDIT: No problems here
EDIT2: perhaps this was caused by the big computer outage they had at NPO.nl this evening?
(2013-12-04, 15:34)Peppin Wrote:(2013-11-26, 22:41)Basje Wrote:Sorry, I tried various max bandwidth plus streaming and cached play.(2013-11-26, 22:37)Peppin Wrote: Hi Bas,
Thanks..
Streaming should still work, right?
I will try to post logs later..
(2013-11-24, 18:13)Basje Wrote: There is quite some discussion about the pull request. I merely made a fix to address your problem. But apparently the actual issue (the way it all works at the moment) is not ideal. So I don't know if they will accept the pull request. But I am working on it. Are you able to compile XBMC yourself? If so, then you can compile a custom version with my fix in it.Finally got some time again to furter setup xbmc. It was really busy at school lately. And i've subscribed to this thread by email, otherwise i'll forget again .
The Pull request was accepted today and merged into master: 771a234
So it will be in the next nightly and then in the November Alpha of 13.0.
(2013-12-14, 04:11)Ravetrancer Wrote: Ill write this inboth English and Swedish.
My english may be little poor when explaining and maybe theres a swede that will understand me better.
This is about Kanal 5 Play on swedish television.
I read some pages back that some are experiencing shows that stip working after about 15-20 sec.
I have the same issue.
Ive tried to see why this is happening and ive come to this conclusion.
All swedish shows work perfectly.
The shows from USA like Big bang theory are those who stop working after 15sec. This is also for Arrow.
This is really strange.
These 2 shows are also the ones that can not be AIR PLAYED. All swedish shows can be air played. When trying to air play them it says "we dont have the rights to air play this show"
Somehow i find this to be connected somehow, the xbmc that wont play more than 15 sec for Big Bang and Arrow and when trying to air play the show from the ipad it says that Kanal 5 doesnt have the right to air play it.
Why do all swedish produced shows work on kanal 5 with XOT but not the American?
I hope that someone can figure it out.
It doesnt matter which Xbmc or openelec i use, neither whichversion ofXOT i use.
On Swedish.
Har testat med både xbmc och openelec, olika versioner och även XOT olikaversioner.
Alla svenska program går att spela upp felfritt på xbmc och Kanal 5s utbud. Det är bara de amerikanska som bryter efter iss exakt 15sek.
Jag kan inte förstå varför detta händer och hoppas att någon mer insatt i kodning mm har ett svar.
Det påminner mig lite om air play funktionen på min ipad. Alla Kanal 5s svenska program går att köra med air play till xbmc förutom de amerikanska Big bang Theory ochArrow.
Det är ett litet lås på air playikonenoch närman trycker på det så står det att kanal 5 inte har rättigheter att visa programmet via Air Play.
Hoppas nån kan knäcka denna nöt.
//R
(2013-12-14, 10:48)Basje Wrote:I understood absolutely squat of what you explained hehe, im a total lamer when it comes to coding etc. Im ok with finding whatworks and what not.(2013-12-14, 04:11)Ravetrancer Wrote: Ill write this inboth English and Swedish.
On Swedish.
//R
SWF (flash) has some DRM methods to prevent playing streams by other means than the flash player. One is the verification of playback software, which is the SWF file on the website.
If they update the flash player's SWF file , I need to update the Kanal 5 channel in XOT.
It could also be that they require a heartbeat connection to keep playing. XOT does not support this.
Bottom line: of you create a bug report on the XOT google code page, we will look into this.
The DRM is also preventing airplay.
(2013-12-14, 21:59)Ravetrancer Wrote: Do i have to make DEBUG uzg.log or uzgplugin.log and add an
xbmc.log
I dont know howto.
