  • 104
  • 105
  • 106(current)
  • 107
  • 108
  • 151
Release Retrospect v5.5.x Video Add-On
It seems to be a cookie consent issue, easy fix. So please create a bug report so you can verify the fix. After that I can push an update.
(2015-06-03, 07:54)Basje Wrote:
(2015-05-28, 00:27)vovakova Wrote: Hi
is it possible to add Yle Areena (Finland) and 4od for channel 4 UK?
Could you add seperate feature requests for these on the Retrospect Bitbucket issue tracker?
@vovakova @Basje This channel request iof YLE Areena/Arena is tied to my already posted feature request of YLE 5: https://bitbucket.org/basrieter/xbmc-onl...in-swedish.
Also check out this, @vovakova: http://forum.kodi.tv/showthread.php?tid=...pid1958164. Makes it possible to watch YLEs live channels abroad. It would be good to have here in Sweden to watch YLE 5, Bas! Smile
@vovakova @Basje This channel request is tied to my already posted feature request of YLE 5: https://bitbucket.org/basrieter/xbmc-onl...in-swedish.
It's on the todo list in the issue tracker. I will see if I can make the live channels work.
(2015-06-03, 07:54)Basje Wrote: Could you add seperate feature requests for these on the Retrospect Bitbucket issue tracker?
Thumbs up, as always!
(2015-06-13, 20:55)Basje Wrote: It seems to be a cookie consent issue, easy fix. So please create a bug report so you can verify the fix. After that I can push an update.
I see you already pushed it through. Thanks alot Bas!
Yeah, I hate it if things don't work. And I had a spare moment this weekend, so I pushed the update myself.
For the next time, just report the issue on the BitBucket issue tracker. I hardly ever use Retrospect myself and don't always notice if something breaks.
hi bas,
i use your Retrospect but the live dutch channels ned 1 en ned 2 enz i caannot stream, what i am doining wrong, please help
pinnoes
(2015-07-06, 15:08)pinnoes Wrote: hi bas,
pinnoes
What version of Retrospect are you using and did you get the lateste update of the NPO channel? That information is availabe in the Retrospect log.
pinnoes
hi Bas
Where i can find the NPO channel update?
i install this net.rieter.xot-4.0.0.zip. and this net.rieter.xot.repository-1.0.5.zip
[/quote]
thanks
pinnoes
pinnoes
hi Bas
thanks
pinnoes
[/quote]
it should be updated automatically. Just have a look at the logfile. Or post a full log in pastebin.com
hi bas
i have version 4.0.0
how i can see the retrospect log
pinnoes
Hi Pinnoes, please see here for all the info: http://www.rieter.net/content/xot/troubleshooting/
You are running Retrospect 4.0.0 but all the channels have 4.0.0.x versions. Those are in the log.
Hi Bas,
Is this prehaps a startingpoint for a addtition to retrospect?
https://github.com/wouter0100/nlziet-api
kind regards,
basco
(2015-07-27, 16:28)basco Wrote: Hi Bas,
kind regards,
basco
It sure could be. Can you add it as a feature request on the bitbucket issue tracker?
ok, i posted it on your bugtracker.
  • 104
  • 105
  • 106(current)
  • 107
  • 108
  • 151
Retrospect v5.5.x Video Add-On7
