I recently installed retrospect and can't get the channels to work, I keep getting the error message "the selected item dies not have any streams associated" or I get the one or more items failed to play
How can I fix this?
I already updated the channels
Henk31
Junior Member
2017-06-25, 10:39
(This post was last modified: 2017-07-01, 10:30 by Henk31.)
When I update with the latest Milhouse build and start Retrospect it causes Kodi to crash. The latest Milhouse build which give no problems is 0603
10:29:31.278 T:1942835216 WARNING: Label Formating: $VAR[GlobalFanartVar] is not defined
10:29:54.279 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -118; absolute index: -5) in another category in old setting condition "eq(-118,Sjuan [TV7])" for "channel_tv4play_se_username"
10:29:54.280 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-118,Sjuan [TV7])" of old setting definition for "channel_tv4play_se_username"
10:29:54.280 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -119; absolute index: -5) in another category in old setting condition "eq(-119,Sjuan [TV7])" for "channel_tv4play_se_password_set"
10:29:54.280 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-119,Sjuan [TV7])" of old setting definition for "channel_tv4play_se_password_set"
10:29:54.280 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -120; absolute index: -5) in another category in old setting condition "eq(-120,Sjuan [TV7])" for "channel_tv4play_se_password"
10:29:54.280 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-120,Sjuan [TV7])" of old setting definition for "channel_tv4play_se_password"
10:29:54.281 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -121; absolute index: -5) in another category in old setting condition "eq(-121,Sjuan [TV7])" for "channel_tv4play_se_token"
10:29:54.281 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-121,Sjuan [TV7])" of old setting definition for "channel_tv4play_se_token"
10:29:54.282 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -124; absolute index: -11) in another category in old setting condition "eq(-124,TV12 Play)" for "channel_tv4play_se_username"
10:29:54.282 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-124,TV12 Play)" of old setting definition for "channel_tv4play_se_username"
10:29:54.282 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -125; absolute index: -11) in another category in old setting condition "eq(-125,TV12 Play)" for "channel_tv4play_se_password_set"
10:29:54.282 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-125,TV12 Play)" of old setting definition for "channel_tv4play_se_password_set"
10:29:54.283 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -126; absolute index: -11) in another category in old setting condition "eq(-126,TV12 Play)" for "channel_tv4play_se_password"
10:29:54.283 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-126,TV12 Play)" of old setting definition for "channel_tv4play_se_password"
10:29:54.283 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -127; absolute index: -11) in another category in old setting condition "eq(-127,TV12 Play)" for "channel_tv4play_se_token"
10:29:54.283 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-127,TV12 Play)" of old setting definition for "channel_tv4play_se_token"
10:29:54.297 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -187; absolute index: -5) in another category in old setting condition "eq(-187,Q2.be)" for "mediaan_username"
10:29:54.297 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-187,Q2.be)" of old setting definition for "mediaan_username"
10:29:54.297 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -188; absolute index: -5) in another category in old setting condition "eq(-188,Q2.be)" for "mediaan_password"
10:29:54.297 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-188,Q2.be)" of old setting definition for "mediaan_password"
10:29:54.298 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -189; absolute index: -5) in another category in old setting condition "eq(-189,Q2.be)" for "mediaan_password_set"
10:29:54.298 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-189,Q2.be)" of old setting definition for "mediaan_password_set"
10:29:54.298 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -190; absolute index: -5) in another category in old setting condition "eq(-190,Q2.be)" for "mediaan_signature"
10:29:54.299 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-190,Q2.be)" of old setting definition for "mediaan_signature"
10:29:54.299 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -193; absolute index: -11) in another category in old setting condition "eq(-193,Stievie)" for "mediaan_username"
10:29:54.300 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-193,Stievie)" of old setting definition for "mediaan_username"
10:29:54.300 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -194; absolute index: -11) in another category in old setting condition "eq(-194,Stievie)" for "mediaan_password"
10:29:54.300 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-194,Stievie)" of old setting definition for "mediaan_password"
10:29:54.300 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -195; absolute index: -11) in another category in old setting condition "eq(-195,Stievie)" for "mediaan_password_set"
10:29:54.300 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-195,Stievie)" of old setting definition for "mediaan_password_set"
10:29:54.301 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: cannot reference setting (relative index: -196; absolute index: -11) in another category in old setting condition "eq(-196,Stievie)" for "mediaan_signature"
10:29:54.301 T:1942835216 WARNING: CAddonSettings[net.rieter.xot]: failed to parse visible condition "eq(-196,Stievie)" of old setting definition for "mediaan_signature"
1/7: Problem solved: removed Retrospect and did a new install
Raspberry Pi4 (2x), Raspberry Pi5
Kodi Omega Beta2, Aeon MQ9 Mod-1.0.9
Very, very sad to hear this, but you're decision is wise - you should under no circumstances risk a law suit. As you say, there's a hunt for illegal Kodi add ons. Although Retrospect is not illegal, one never knows what the hunters may do.
Thank you for all your work and time, Basje! I hope you will find legal advice that's positive for Retrospect. Let us know what is happening.
[Written by my thumbs on a state-of-the-art Ericsson Hotline 450.]
Feel welcome everyone to donate some money to Basje for legal advise. I will once I get back home. Thanks for the great work and I totally understand that you want to prevent personal risks
If you somehow could work out some premium service for all play channels collected for a mountly fee at a reasonably cost I would gladly pay. To be honest, use several apps for different channels is a hassle and on top of that, using apps at all on my android tv-box is not user friendly.
My setup with Retrospect is excellent. I use Super Favorites to build my own page. Nothing else comes close to this user experience.
I would hate to replace this with something else.
Btw, I mainly use the Swedish channels. Do you know their standpoint about this?
I believe that you slightly misunderstood me there. My idea is that maybe you could work out some kind of contract with the owners of those channels to distribute their channels. Similar to how Spotify works.
Any news on this? I am really really nrevous for this as Retrospect is the addon I use the most and the only good way to access Norwegian tv... I cross all fingers!!
Ketil
