2009-04-21, 23:05
I can't find 'RTL Voetbal' on the XOT list there for RTL. Only 'Voetbal international', when i click on that, i just get an endless 'loading screen'.
tikkiew Wrote:Did you read the first post on a topic soder?
There mostly is more information.
Don't know if this in this case will solve your problem.
soder Wrote:How do I update this script with the new channels? Ive tried the swedish tv6, tv3 and SVT play, but it doesnt work.
Ive read something about doing an update, but I cant find that option. I use XBMC for Linux with the MS oem remote.
/Söder
Basje Wrote:XOT consists of 3 things: skins, channels and a framework.
You can download the complete package (Framework + channels + skins) from http://www.rieter.net/uitzendinggemist/
On GoogleCode you will only find channels and skins. The framework is only available from the site above.
soder Wrote:So that file isnt enough? XOT-Uzg.v3.2.0b4.zip ?
/Söder
Basje Wrote:That one is the complete package. Don't forget to update both the plugin and the script.
soder Wrote:What to update?
1. Ive put the the file XOT-Uzg.v3.2.0b4.zip in ~/.xbmc/plugins/video
2. Ive unziped the file.
3. In XBMC i goes the videos/plugin and choosed the plugin.
What is there to do next?
EDIT
Can it be that the default mode doesnt work with Aeon?
/Söder
Basje Wrote:The plugin version seems bugged. Run it as a script and it will work like a charm. I will fix the plugin as soon as possible.
