2009-12-16, 23:06
Quote:Is it also possible to get SVT Prima to work? (HD version of SVT Play at http://playprima.se/)
brulsmurf Wrote:Confirmed to work on a very recent build with Vista 32 bit Thanks a lot for this fix.
Would it be possible for you to add your XOT-UZG repository to the SVN Updater, so that users can update it more conveniently? For instance, my HTPC rig has no keyboard/mouse attached to it, so updating by downloading XOT-UZG manually and then unzip it in the correct place is a bit of a hassle for people like me. I'm perfectly happy going through all that "trouble" to enjoy my Uitzending Gemist of course, no complaining - but if it's an easy step for you then I would appreciate it a lot.
+1
Well, first of all me and my girlfriend wants to thank you for your extraordinary work!!
I got confused when i updated my XOT a couples week ago, we have always installed XOT in the video plugin folder, and the used xbmc's "add source" to make shortcuts to our favorite channels so they appeard direct in the "Video" menu. (using Showmix skin)
After the update XOT doesn't work anymore, just nothing happend when we tried to start it. So after a little reading here we installed it in the scripts folder, and viola, it works again!
Now to the question; is it any reason that XOT now is a script instead of a plugin?
Speaking for myself i liked it a little better when it worked as a plugin because it is very convenient to add shortcuts to the most used channels. Less clicks to get started so to say.
So if it possible i will vote for XOT to bet back being a plugin instead!
BTW, im using xbmc ver. 22516 on windows 7 (X64) if it matters.
