yallah
Senior Member
Hi
Xarcade still working for libreleec (KODI18) with retroplayer ?
yallah
Senior Member
Hi
I don't know if Xarcarde is ready but not working here.
I Install xarcade driver in system menu, put udev driver for joystick but nothing
Normal ?
garbear
Team-Kodi Developer
I can't see the error in the log. I'll have to reproduce locally. My house is under construction, so it'll be a while before I can address this.
garbear
Team-Kodi Developer
Make sure X-Arcade Tankstick add-on is enabled (it looks so in your log)
yallah
Senior Member
yes it is and I didn't see also red light on xarcade
garbear
Team-Kodi Developer
You say "not working". You need to be more specific. If you try to press every button/stick, is there erratic input, or is there no input?
yallah
Senior Member
no input nothing happen in GUI mode or in game. it's same
garbear
Team-Kodi Developer
then it's probably not a Kodi problem. The add-on intercepts keyboards and emulates joystick. if there's no keyboard input, the problem isn't with kodi.
yallah
Senior Member
Ok thx
Certainly problem with my xarcarde, I will try with retroarch and come back to you if it's working
