it would be nice if we could add our music from google play and tidal to our music library and able to change the music information like cdART because sometimes it is wrong because I have both and the kodi addons are but sometimes the services get the information wrong that the scrappers have correct or being able to change it ourselves
Since forever, Kodi has had a switch to turn off showing artists that only appear on compilation albums - in my view this is a "good thing" as otherwise the artist list, which is my goto method for finding an album or track, is horribly cluttered and enormous.
The thing is, when Kodi scans in a compilation album, it fetches artist info for all of these compilation artists, and if you have a lot of compilation albums (like I do) it takes hours.
Would it be possible therefore to either add an option to NOT scrape artist data for compilation albums, or just not scrape it if "Show artists who only appear on compilations" is turned off ? If there is an artist that a user wants details on, this can still be obtained via the context menu "Artist Information" and then hitting "reload".
Learning Linux the hard way !!
jjd-uk
Team-Kodi Member
If we go the way of making music scraping more like videos then you'll be able to exclude a folder from scraping, so you could have a compilation folder containing all those albums and set to local data only.
jjd-uk
Team-Kodi Member
I don't think you followed, in videos it possible to go to a sub folder and overide the global settings made when you add the source.
So you could have:
- Music (main source folder - set content for scraping defaults)
---- Artists / Albums (subfolders in source - inherits settings for the source)
---- Compilations / Albums (subfolders in source - set to local overiding source defaults)
Thus the Compilations folder would never scrape online date.
I did consider moving my compilations directory into a completely different path and adding that as a source, turning off all the settings, and just let Kodi scrape the tag values into the library. I think this would probably achieve the right result although I'm not sure of the effect it may have on the music library as a whole. It's also a bit of a faff to have to remember to change settings if you add an ordinary album or a compilation before you update the library.
Silki
Senior Member
Right I've managed to peace together a working Addon that query's ronie GlobalSearch Script from the Context menu passing across the Artist and also one that passes the Track title.
Ill try it for a day or too and then perhaps add it to forum if anyone is interested.
This seems like a good place to repost my music-related request of a few years back, thanks for the thread Dave.
Music PartyMode has some awesome potential to behave as an interactive jukebox, mostly because of one behavior: if one starts up PartyMode and then manually browses and adds additional tracks to the queue, the new tracks get bumped up the list and begin playing as soon as the current track is finished. Then when any manually added tracks are finished, random playback resumes. Perfect. It's a jukebox that never stops playing, and human requests gets priority.
The problem is, PartyMode doesn't respect the setting "Queue songs on selection". If one browses to find a new track and simply clicks or presses "enter" or the default button on a remote, the new song starts playing immediately, abruptly cutting off whatever was playing before. No good. Guests must be taught about context menus and the letter q or whatever is available on the remote, it's awkward and not fun and prone to mistakes.
Honestly it feels like a bug, but the devs who happened across my trac item a few years ago disagreed, or couldn't be bothered, so whatever the case I'm hoping someone might notice and support this request. Thanks for reading.
Any chance to see support for itunes playlists? I am using playlists extensively. I know I can already export them, but that's manual and painful. A simple integrated way in Kodi would be great!
Server: Asus Sabertooth Z77 | Intel Core i5 3.4 GHz | 16 GB DDR3 | 128 GB SSD, 82 TB (9 x 6 TB, 7 x 4 TB)
HTPC 1: Raspberry Pi 2 | HTPC 2: Raspberry Pi 2 | HTPC 3: Raspberry Pi
