wrxtasy
Sorry that ask. When will the first assembly Openelec for C2 or it will not be for C2?
Loki69
Junior Member
pretty sure wrxtasy has said that the openelec for the C2 will launch when the C2 is available commercially no point doing it earlier
wrxtasy
Which Wi-Fi adapters expect wi-fi "odroid" are supported for C2 Openelec?
When will it available for buying?
No idea, that would be a specific question only HardKernel could answer.
Just a heads up. You really only need a Case and the Board itself. The C1 and C2, work happily with just using a Mini otg to usb cable plugged into a Phone charger for power. And thats with a DVB USB Tuner attached and a few other small USB dongles. I also use the responsive built in IR port, so don't even use an extra remote.
Start adding 2.5" HDD's and you need a proper power supply, like all ARM gear.
Also I would only get WiFi / BT usb dongles from HardKernel so you know 100% they are going to work. Or at the very least ask them directly on their specific C2 Sub-forum about compatibility before purchase.
rafikW
Senior Member
Odroid C2 really looks very promising.
Can you please compare C1+ with C2 in the scope of HD Audio passthrough HDMI and CEC?
Are you going to release new OpenELEC especially for Odroid C2 which will utilize 64bit architecture or it can be easily OpenELEC for C1+ used?
