2016-09-05, 22:31
Out of curiousity : why can we have Krypton working on Raspberry and only Jarvis on Odroid?
(2016-09-05, 22:31)propergol Wrote: Out of curiousity : why can we have Krypton working on Raspberry and only Jarvis on Odroid?
(2016-09-06, 14:19)wrxtasy Wrote: In depth testing till it breaks... Ha ha, looks like you have found the soft AMLogic LibreELEC Audio underbelly !!
I have no AVR to test, but from user reporting back I seem to recall if any HDMI AVR is involved, a slight ms Audio setup tweak from the Kodi OSD is needed, then "Save as default for all Videos"
No idea what is going on with switching Audio tracks to be honest. AML Audio needs a LOT of work put into it, both in LE / Linux and Android. It really needs some long overdue attention from knowledgable Kodi Audio - AML Kernel guys. I will be releasing an modded HDMI Audio test version soonish.
Sync playback to display does nothing on AML devices as video Bypass rendering is used. Kodi has no control.
The Kodi Temperature readout actually over reads as well on the C2. I leave mine on 24/7, and never experience any slowdowns or crashes.
Make sure you are using the latest .tar LE 7.1 update that fixes a bad memory leak in Kodi too:
LibreELEC-Odroid_C2.aarch64-7.1.0.fixmemleak.tar
I have found on the 1GB Hub, if you use the Video Cache Settings from Example #4 found here (ie 450MB of free RAM reqd), you can actually crash a 1GB AML device regularly. I now use Example #3 on the Hub and all if good !
http://kodi.wiki/view/HOW-TO:Modify_the_video_cache
LE 7.1 on the C2 is using Example #4 by default to help with 4K video playback buffering.
(2016-09-06, 14:36)propergol Wrote: I will receive my C2 in the next hoursYou will be downloading an Unstable LE 8.0 Kodi Krypton Beta development version with the SD creation tool. Thats fine if it suits your needs by LE 7.1 has a whole bunch more Kodi features that actually work properly, plus a bunch of included extras you won't know about till needed.
I have downloaded the SD creation tool that itself downloaded LibreELEC-Odroid_C2.aarch64-7.90.005.img.gz
I am confused : is you version LibreELEC-Odroid_C2.aarch64-7.1.0.fixmemleak.tar newer than the one downloaded by the sd creation tool?
(2016-09-06, 12:37)wrxtasy Wrote: Until you test (Krypton) deinterlacing reliability with Live TV, DVD ISO playback, and then 23.976/29.97/59.94fps video sync, and look for 41 second video frame upsets when Kodi Dynamic refresh switching is used.
There is currently no AML Frame Rate Automation for those Fractional Refresh Rates for smooth video playback on any AML Krypton Platform, unless something has drastically changed lately.
(2016-09-07, 20:34)wrxtasy Wrote: The Fix from memory:
In Audio Settings > Keep Audio Device Alive > OFF
