  • 58
  • 59
  • 60(current)
  • 61
  • 62
  • 116
ODROID C2 S905 2GB RAM HDMI 2.0 $46
(2016-12-07, 12:27)zbigzbig20 Wrote: @wrxtasy, nice job. Can you release your new build for play2 as well ? @codesnake wrote something about updated dvb driver for play2 so maybe will be possible to include it in you great build.
Regards
I very likely will now this new AML Kernel is bedded down for the C2.
Decided to go Back to the Future today and use AMLogic's previous version of GPU video drivers.... and well the results speak for themselves...especially with a slight 1.752GHz CPU and 1104MHz RAM Overclock.
You would swear it was Intel under the hood ! Big Grin
LibreELEC-Odroid_C2.aarch64-7.1.1.r5p1.tar
(2016-12-08, 13:56)wrxtasy Wrote: I very likely will now this new AML Kernel is bedded down for the C2.
Help me out here please. Is this tar to be installed on the C2 or is it for the play2? Because I installed the December update just yesterday.
Greetz,
[email protected]_
oDroid C2 - 8GB eMMC -Running LibreELEC (latest stable)
Synology DS215+ - 8+6 TB | Synology DS211 - 4+4 TB - No RAID | Homebrew server OpenMediaVault - 10 TB - LVM | Ubuntu Server 18.04.01 -10 TB - RAID5
Philips 50PFK5300 | Sony HT-XT100 Soundplate
Scanning my media with MediaElch
(2016-12-08, 13:56)wrxtasy Wrote: Decided to go Back to the Future today and use AMLogic's previous version of GPU video drivers.... and well the results speak for themselves...especially with a slight 1.752GHz CPU and 1104MHz RAM Overclock.
Thank you for all the work. System operates like a mf.
(2016-12-08, 22:00)[email protected]_ Wrote: Help me out here please. Is this tar to be installed on the C2 or is it for the play2? Because I installed the December update just yesterday.
C2 only because WeTek devices have a different U-Boot and Hardware descriptor setup. I can port most patches to Hub / Play2 easily when I get time.
Ha Ha.
Now that we have achieved M.F. status this Skin works nicely with the little M.F. C2 beastie: Wink
How to Install Aeon MQ7 Skin 4 Kodi
Oh yeah, that's the skin i'm using, it's very good and usable already with your Aug image and Oct update without overclocking cpu and ram but now it's even better!
OK, so I decided to install LibreELEC-Odroid_C2.aarch64-7.1.1.LIRC.tar. Had some problems with my MCE remote. But thanks to the invaluable help of @Merlin.KIS I resolved that issue. Look at this post (on another forum) for the solution.
Greetz,
[email protected]_
Regards
Forgive my confusion, but are the adjusted CPU/RAM clocks built into this December update? Thank you for all you do for us C2 owners. Keep up the excellent work!
I spoke too soon Sad
After a cold boot the MCE remote again didn't work. I will have a look over at the other forum to see if I can find other solutions.
Kodi > System > LibreELEC > Services > Lirc (bottom of page)
You may have to re-enable Lirc with this LIRC.tar version.
(2016-12-09, 18:26)madhacker7 Wrote: Forgive my confusion, but are the adjusted CPU/RAM clocks built into this December update? Thank you for all you do for us C2 owners. Keep up the excellent work!
From LE 7.1.1 release notes...
- Ability to Overclock DDR3 SDRAM included in this release. Config instructions in this thread
Look for the boot.ini file on the SD Card / eMMC for instructions about CPU Clocks. I can only use Max 1.752GHz
(2016-12-10, 09:17)wrxtasy Wrote: Kodi > System > LibreELEC > Services > Lirc (bottom of page)
*snip*
Well, that did it Smile
Had to switch to Confluence 'cause I couldn't find LibreELEC settings in Aeon Nox.
Greetz,
[email protected]_
(2016-12-10, 10:13)[email protected]_ Wrote: Had to switch to Confluence 'cause I couldn't find LibreELEC settings in Aeon Nox.
You have add a custom button for this.
frontend software - tvOS | android tv | win10 | kodi krypton
frontend hardware - apple tv | nvidia shield tv | yamaha rx-a1020 | quadral 5.1 | samsung le40a789
backend software - debian | kernel 4.14 | proxmox | omv | zfs raid-z2 | docker | emby | vdr | vnsi | fhem
backend hardware - supermicro x11ssh-ctf | xeon E3-1240L-v5 | 64gb ecc | 8x4tb wd red | dd max s8
No it should be under 'programs' in any skin.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
(2016-12-11, 01:20)nickr Wrote: No it should be under 'programs' in any skin.
Which I disabled Programs since the beginning of using XBMC. Will have a look there. Otherwise I' ll make a separate entry (somehow)
Greets,
[email protected]_
Me too. Big Grin
Greetings Hoppel
Well, I checked and in Aeon Nox it is under Apps. But apart from LibreELEC setting I don't use any apps. So I created an entry under System called LibreELEC and that starts the LibreELEC add-on.
I am a happy camper again Nod
Greetz,
[email protected]_
  • 58
  • 59
  • 60(current)
  • 61
  • 62
  • 116
  • 10 Vote(s) - 4.1 Average
ODROID C2 S905 2GB RAM HDMI 2.0 $464.110
