Away from my LE compiler machine for a while thousands of KM's from home. Post #1548 of this thread has all the current release details.
Hello
i need help.
Just tried to move from raybuntu build kb19 to wrxtasy as per post #1548 (including the nocompat tip). Everything went well but TvHeadEnd doesn't want to load.
Shared library failed to load as per
00:52:30.745 T:545608634592 ERROR: Unable to load /storage/.kodi/addons/pvr.hts/pvr.hts.so.3.4.27, reason: /storage/.kodi/addons/pvr.hts/pvr.hts.so.3.4.27: wrong ELF class: ELFCLASS32
I guess this is 32/64bits related but even when removing the client rebooting and then reinstalling the error remains the same.
What can I do ?
Now I have switched to wrxtasy I can no longer ssh access my device. libreelec root password is not working. Why ?
"le" (no quotes) or you're making a typo when entering it. ;-)
What a pity : just found out wrxtasy build does not auto switch my TV framerate to 24fps when required whereas it is supposed to do so and rb build does... 😓
What can I do ?
To be more precise : 24fps movie auto switch is ok. 23,976fps movie auto switch not working.
My gui resolution is 1920x1080p/50fps (same behaviour when 60fps set).
Query- will the Odroid C2 support hdmi 2.0a, with audio pass through for kodi via Libreelec - HDR UHD 4K Dolby Vision, Atmos DTS-X etc - have a NAS box with 4k videos and a good surround sound system
wrxtasy is this possible
nickr
Retired Team-Kodi Member
2018-01-14, 00:44
(This post was last modified: 2018-01-14, 00:44 by nickr.)
According to hardkernel, it is HDMI 2.0
It supports passthrough audio over HDMI.
HDR not supported AFAIK.
Try looking at post 2 in this thread.
If I have helped you or increased your knowledge, click the 'thumbs up' button to give thanks :) (People with less than 20 posts won't see the "thumbs up" button.)
