Wouldn't that be a downgrade, though? Current LE official build is 8.2.4.
ODROID C2 eMMC 16GB | LibreELEC-Odroid_C2.arm-9.0.2 + fTV | Logitech Harmony Elite remote | LG 55EG910V
Just drop in the .img.gz into the Update folder - it will auto update the same as the .tar
2018-04-21, 19:56
(This post was last modified: 2018-04-21, 19:57 by BoxFreak.)
I'm running wrxtasy-raybuntu-media_build version 8.0 and I guess it's not possible to autoupdate to this LibreELEC-Odroid_C2.aarch64-8.2.2-NR-LFE-SUSPEND.img. I get an error that it's not compatible with C2. So just clean install?
Odroid C2 running CoreElec
mika91
Senior Member
2018-05-03, 11:55
(This post was last modified: 2018-05-03, 11:55 by mika91.)
Hi wrxtazy,
Any recommands about kodi settings for best pictures quality on 1080p TV with SD or 720p materials?
The image is notably better with my rpi (Mitchell Netravali upscaling I guess) compared to the OC2 with default settings.
Can I use bi-cubic or lanczos3 upscaling with OC2 (and yadif deinterlacing) ?
Need hardware or software decoder?
I’ve got a resolution down switching patch that I have been testing so 720 content will be output at a 720p resolution.
It also includes a Kodi settings adjustable switch. Will be in the next release real soon.
You cannot use Bicubic or lanczos3, not enough CPU ponies on AMLogic devices.
