Quick question: Is this addon supposed to work on Kodi M? I'm getting lots errors for all kinds of addons, python errors specifically for AB.
AFAIK, AB is not compatible with Python 3, so trying to run it in a current Matrix nightly or the current Windows HDR fork build 3.0.1 is not possible. Posting log excerpts of python exceptions without a full debug log is not going to help in resolving your problems. If you post a full log, at least we would know if you are attempting to run AB in python 3. Some things, like trying to decode a string in python 3 are pretty clear from the exception, but it really helps to have a full debug level log.
scott s.
Is it possible to add an option in the configuration settings to have AB not popup while watching a movie or TV show?
Regards,
Shedrock
Disable the setting "Show final artwork update count notification" in the Advanced add-on settings. If the progress bar stays over the video that is a skin thing.
2019-12-21, 03:20
(This post was last modified: 2019-12-21, 03:33 by leejk.)
There seems to be problem with setting central info directory for move set artwork in advanced settings. It seems that once the network location is set, you can’t change it to another location outside of that root file system. I was wanting to change it from an nfs location to a Windows mapped drive, and could not.
Also I noticed that even though in advanced settings I have the save artwork with movie file base name turned off, new artwork is named that way anyways.
does the Isengard version of this still work? i get an error that it won't work and to check the log each time i start SPMC. any ideas?
