  • 9
  • 10
  • 11(current)
  • 12
  • 13
  • 171
WIP Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread
can I skip the profile-dialog?
http://abload.de/img/unbenannt9zy8v.png
(2016-03-14, 00:11)dirtydesaster Wrote: can I skip the profile-dialog?
https://github.com/DanCooper/Ember-MM-Ne...d1487de94c
(2016-03-13, 19:00)T-bird_se Wrote: Found a bug for clearart, logos ... then it's a stacked movie, saying not found, syncing from context menu in file list
Log snippet included
Quote:2016-03-13 17:39:47.4104;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;7;TRACE;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | Start syncing process...";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_26_SearchMovie.MoveNext;15;WARN;"[APIKodi] [Lilleman] SearchMovie: ""\\Diskstation\xbmc\Film\Sagan om Ringen\Sagan om ringen - Härskarringen (2001)\Sagan om ringen - Härskarringen (2001).bluray.cd1.mkv"" | NOT found in host database!";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;15;TRACE;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | NOT found in database, scan directory on host...";
2016-03-13 17:39:47.7848;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_41_VideoLibrary_ScanPath.MoveNext;15;TRACE;"[APIKodi] [Lilleman] ScanVideoPath: ""smb://DISKSTATION/XBMC/Film/Sagan om Ringen/Sagan om ringen - Härskarringen (2001)"" | Start scanning process...";
2016-03-13 17:39:48.2684;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_45_IsScanningVideo.MoveNext;15;TRACE;[APIKodi] [Lilleman] IsScanningVideo: True;
2016-03-13 17:39:49.5164;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_45_IsScanningVideo.MoveNext;15;TRACE;[APIKodi] [Lilleman] IsScanningVideo: False;
2016-03-13 17:39:49.7348;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_26_SearchMovie.MoveNext;15;WARN;"[APIKodi] [Lilleman] SearchMovie: ""\\Diskstation\xbmc\Film\Sagan om Ringen\Sagan om ringen - Härskarringen (2001)\Sagan om ringen - Härskarringen (2001).bluray.cd1.mkv"" | NOT found in host database!";
2016-03-13 17:39:49.7348;generic.Interface.Kodi.Kodi.APIKodi;generic.Interface.Kodi.Kodi.APIKodi+VB$StateMachine_32_UpdateInfo_Movie.MoveNext;15;ERROR;"[APIKodi] [Lilleman] UpdateMovieInfo: ""Sagan om ringen: Härskarringen"" | NOT found on host! Abort!";
2016-03-13 17:39:49.7348;generic.Interface.Kodi.KodiInterface;generic.Interface.Kodi.KodiInterface+VB$StateMachine_74_GenericRunCallBack.MoveNext;1;WARN;[KodiInterface] [Lilleman] RunGeneric Movie Update | Sync Failed: Sagan om ringen: Härskarringen;
2016-03-13 17:39:49.7348;EmberAPI.ModulesManager;EmberAPI.ModulesManager.RunGeneric;1;TRACE;[ModulesManager] [RunGeneric] [Start] <Notification>;
2016-03-13 17:39:49.7504;EmberAPI.ModulesManager;EmberAPI.ModulesManager.RunGeneric;1;TRACE;[ModulesManager] [RunGeneric] Run generic module <Notifications>;
2016-03-13 17:40:09.3753;Ember_Media_Manager.frmMain;Ember_Media_Manager.frmMain.frmMain_FormClosed;1;INFO;====Ember Media Manager exiting====;
We can't sync multi part videos. Kodi save that with a strange path/file name in database. But we are working on a solution.
German Ember Media Manager Support
Daily Builds - Link
Latest official Ember-MM version - Ember Media Manager 1.4.x
Should be fixed in Alpha 12: Commit and Commit
Daily Builds - Link
(2016-03-14, 12:11)DanCooper Wrote: Should be fixed in Alpha 12: Commit and Commit
You are unbelievable fast Smile
Thx
(2016-03-10, 07:48)orbtwin Wrote:
(2016-03-10, 01:03)DanCooper Wrote:
(2016-03-09, 00:38)orbtwin Wrote: i can't mark a show as watched.
all season and episodes are marked as watched so
If you have watched a tv show, do you not watched all episodes?? Huh
EDIT:
(2016-03-10, 00:28)T-bird_se Wrote: I seen the same
Importing library to Ember and just one show get the view mark but all seasons an episodes are marked as viewed
If I try to mark it as unseen all marks is gone as expected, but if I try to set it as seen again it's back to not mark the show itself
Oh, now i understand the problem Big Grin Yes, it's a bug in tvshow view with calculating. Will be fixed in next alpha.
EDIT: I hope it will be fixed in next alpha Tongue
thanks again for the answer.
i explained bad
Also fixed for Alpha 12: Commit
Daily Builds - Link
Is there a way to increase the "directory/file.name" past the 256 character limit? Ran into this problem on the initial scrape of my TV directory. I am really not looking forward to finding a way to truncate.
Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
(2016-03-14, 23:20)Hecatonchieres Wrote: Is there a way to increase the "directory/file.name" past the 256 character limit? Ran into this problem on the initial scrape of my TV directory. I am really not looking forward to finding a way to truncate.
Nope, the .NET API supports only 256/260 characters like Windows Explorer. There is an Unicode-API in Windows that we can, but I don't want use that atm. I've no experience whit that and scared to save data in a path that a "noob" user no longer can use to save new files inside this folder with Explorer.
Daily Builds - Link
(2016-03-14, 23:38)solamnic Wrote: Could you please the Greek flag to appear properly... ( i have movies with greek audio and subtitle and a ? appears instead of flag) can you check this?
I think that problem is already posted in our bug tracker. Please tell me which "LongLanguage" and "Language" is saved in NFO.
You can fix your Languages.xml to fix that issue. Simply modify the "Alpha2" or "Alpha3" to the correct value like this:
<Language>
    <Alpha2>el</Alpha2>
    <Alpha3>ell</Alpha3>
    <Name>Modern Greek</Name>
</Language>
Daily Builds - Link
<Language>
    <Alpha2>el</Alpha2>
</Language>
Checking language.xml has correct the above values
here is part of nfo file (that displays Greek language as gre not el, or ell)
<streamdetails>
            <video>
                <aspect>1.778</aspect>
                <codec>h264</codec>
                <durationinseconds>5286</durationinseconds>
                <height>1080</height>
                <scantype>progressive</scantype>
                <width>1920</width>
            </video>
            <audio>
                <channels>8</channels>
                <codec>dtshd_ma</codec>
                <language>eng</language>
            </audio>
            <audio>
                <channels>6</channels>
                <codec>ac3</codec>
                <language>gre</language>
            </audio>
            <subtitle>
            </subtitle>
            <subtitle>
            </subtitle>
        </streamdetails>
    </fileinfo>
</movie>
<Language>
    <Alpha2>el</Alpha2>
</Language>
<streamdetails>
            <video>
                <codec>h264</codec>
                <width>1920</width>
            </video>
            <audio>
            </audio>
            <audio>
                <codec>ac3</codec>
            </audio>
            <subtitle>
            </subtitle>
            <subtitle>
            </subtitle>
        </streamdetails>
    </fileinfo>
</movie>
It's a little bit tricky....
MediaInfo use "gre" as Alpha3 code
The Language.xml use "ell" as Alpha3 and "el" as Alpha2.
The flag image calls "el.png".
"B" (bibliographic)
"T" (terminology)
In comparing to german Alpha codes, "de" and "deu" is correct:
I would say that MediaInfo set the wrong language code and you have to change that manually in our Metadata Editor. Than the country flag will be displayed.
Alternative you add this new node to the Languages.xml and copy the flag "el.png" also to "gr.png":
<Language>
    <Alpha2>gr</Alpha2>
    <Alpha3>gre</Alpha3>
    <Name>Greek</Name>
</Language>
Daily Builds - Link
i did the added the node in languages.xml also copied the flag to gr.png..
and everything is ok... Smile
please add it to the next release of ember Smile
also i have many nfo's that produce errors with ember (object not referrence .... etc) but they are accepted by kodi
<?xml version='1.0' encoding='utf-8'?>
<!--YAMJ XML Generated by YANFOE Movies Edition (1.0) - 11/10/2012 00:22:11-->
<movie>
    <id>tt0126029</id>
    <id moviedb="tmdb">808</id>
    <title>Shrek</title>
    <year>2001</year>
    <releasedate>07-09-2001</releasedate>
    <rating>7</rating>
    <votes>1743</votes>
    <outline>It ain't easy bein' green -- especially if you're a likable (albeit smelly) ogre named Shrek. On a mission to retrieve a gorgeous princess from the clutches of a fire-breathing dragon, Shrek teams up with an unlikely compatriot -- a wisecracking donkey.</outline>
    <plot>It ain't easy bein' green -- especially if you're a likable (albeit smelly) ogre named Shrek. On a mission to retrieve a gorgeous princess from the clutches of a fire-breathing dragon, Shrek teams up with an unlikely compatriot -- a wisecracking donkey.</plot>
    <tagline>The greatest fairy tale never told.</tagline>
    <mpaa>U</mpaa>
    <certification>Malaysia:U / Portugal:M/4 / Iceland:L / South Korea:All / South Africa:A / South Africa:PG / Argentina:Atp / Australia:PG / Brazil:Livre / Chile:TE / Finland:K-7 / France:U / Germany:o.Al. / Hong Kong:I / Ireland:G / Netherlands:MG6 / Peru:PT / Philippines:G / Singapore:G / Spain:T / Sweden:7 / Switzerland:7 / Switzerland:7 / UK:U / USA:PG / Greece:K / Norway:7 / Canada:F / Canada:PG / Canada:G</certification>
    <company>DreamWorks Animation</company>
    <language>English</language>
    <set>Shrek Collection</set>
    <videosource>BluRay</videosource>
    <videooutput>720p 24Hz</videooutput>
    <originaltitle>Shrek</originaltitle>
    <top250>0</top250>
    <playcount>0</playcount>
    <tmdbid>808</tmdbid>
    <sorttitle></sorttitle>
    <trailer>http://www.youtube.com/watch?v=W37DlG1i61s</trailer>
    <watched>false</watched>
    <runtime>90</runtime>
    <credits>William Steig</credits>
    <credits>Ted Elliott</credits>
    <credits>Terry Rossio</credits>
    <credits>Joe Stillman</credits>
    <credits>Roger S.H. Schulman</credits>
    <director>Vicky Jenson</director>
    <studio>DreamWorks SKG</studio>
    <studio>Pacific Data Images (PDI)</studio>
    <studio>DreamWorks Animation</studio>
    <genre>Adventure</genre>
    <genre>Animation</genre>
    <genre>Comedy</genre>
    <genre>Family</genre>
    <genre>Fantasy</genre>
    <country>United States of America</country>
    <thumb preview="http://image.tmdb.org/t/p/w342/140ewbWv8qHStD3mlBDvvGd0Zvu.jpg">http://image.tmdb.org/t/p/original/140ewbWv8qHStD3mlBDvvGd0Zvu.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/yC5fpfO9auj9fJ0UYA5MvbRnxHd.jpg">http://image.tmdb.org/t/p/original/yC5fpfO9auj9fJ0UYA5MvbRnxHd.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/4ybHCYMyUUaO2xjB80zh4KjkKsl.jpg">http://image.tmdb.org/t/p/original/4ybHCYMyUUaO2xjB80zh4KjkKsl.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/cGjhCcYhTGWxXlDJMWrK2lUa5PZ.jpg">http://image.tmdb.org/t/p/original/cGjhCcYhTGWxXlDJMWrK2lUa5PZ.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/sMDUEnVJNR2uhtlpXBvyxdE7AM5.jpg">http://image.tmdb.org/t/p/original/sMDUEnVJNR2uhtlpXBvyxdE7AM5.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/c7FFzG19gDZ3LfEltOn2oYuVGS0.jpg">http://image.tmdb.org/t/p/original/c7FFzG19gDZ3LfEltOn2oYuVGS0.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/xqdO57TJ19Gig9FQ6muUP3NtlQI.jpg">http://image.tmdb.org/t/p/original/xqdO57TJ19Gig9FQ6muUP3NtlQI.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/r5xh3IjUSYphyU4RkvZVzYV5rYO.jpg">http://image.tmdb.org/t/p/original/r5xh3IjUSYphyU4RkvZVzYV5rYO.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/jf6mwHe0ieI27RfwE7Vp1ikJuuO.jpg">http://image.tmdb.org/t/p/original/jf6mwHe0ieI27RfwE7Vp1ikJuuO.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/i8v9fbgehOeEHvF6znB1vGrKqDT.jpg">http://image.tmdb.org/t/p/original/i8v9fbgehOeEHvF6znB1vGrKqDT.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/7Oi9GwWatrvf5vTUgQRR7e9A8lM.jpg">http://image.tmdb.org/t/p/original/7Oi9GwWatrvf5vTUgQRR7e9A8lM.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/agDOQeEhdBVUE5XCQbI7kXc9vFW.jpg">http://image.tmdb.org/t/p/original/agDOQeEhdBVUE5XCQbI7kXc9vFW.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/m4FSTv9IR696DT1pikRIvQVGycD.jpg">http://image.tmdb.org/t/p/original/m4FSTv9IR696DT1pikRIvQVGycD.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/elIjJS4JcnmJavvCVM9JXpWsyet.jpg">http://image.tmdb.org/t/p/original/elIjJS4JcnmJavvCVM9JXpWsyet.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/vgoxjAqbIsoukByuDV8psXPb4U0.jpg">http://image.tmdb.org/t/p/original/vgoxjAqbIsoukByuDV8psXPb4U0.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/7WvZmbrnn6S5b0sVY3Yllmn5X0z.jpg">http://image.tmdb.org/t/p/original/7WvZmbrnn6S5b0sVY3Yllmn5X0z.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/aN8MhHTOstg8kuLnMjeiKSIraKM.jpg">http://image.tmdb.org/t/p/original/aN8MhHTOstg8kuLnMjeiKSIraKM.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/n78K1bTOrRBWOlOHRKv6vUnQnpF.jpg">http://image.tmdb.org/t/p/original/n78K1bTOrRBWOlOHRKv6vUnQnpF.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/lh0yryxEPiiwqStP9coBPCuiCrT.jpg">http://image.tmdb.org/t/p/original/lh0yryxEPiiwqStP9coBPCuiCrT.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/nREfX7RKJ208Gj1egGL3rC9EGr1.jpg">http://image.tmdb.org/t/p/original/nREfX7RKJ208Gj1egGL3rC9EGr1.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/t0PsVzYL7Rm8MJZQCDGqweAeMvZ.jpg">http://image.tmdb.org/t/p/original/t0PsVzYL7Rm8MJZQCDGqweAeMvZ.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/zpfCAjbtuehlPs7X0aGT8kv8EBK.jpg">http://image.tmdb.org/t/p/original/zpfCAjbtuehlPs7X0aGT8kv8EBK.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/1tqvTnUm9VabIQXeHxVJCCrdlZ6.jpg">http://image.tmdb.org/t/p/original/1tqvTnUm9VabIQXeHxVJCCrdlZ6.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/uw3KPLQwRcePPPUkxFN9vdC7aEo.jpg">http://image.tmdb.org/t/p/original/uw3KPLQwRcePPPUkxFN9vdC7aEo.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/elqg57hodBUD0D5SoflxlLOlkp3.jpg">http://image.tmdb.org/t/p/original/elqg57hodBUD0D5SoflxlLOlkp3.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/f9CZd5pSiHX63Aqp6TXldE6Cetp.jpg">http://image.tmdb.org/t/p/original/f9CZd5pSiHX63Aqp6TXldE6Cetp.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/OgdluFPui5xSNiPEa68xvCeWMW.jpg">http://image.tmdb.org/t/p/original/OgdluFPui5xSNiPEa68xvCeWMW.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/PqDpPZwPEszATI5PMXBmAcKNZA.jpg">http://image.tmdb.org/t/p/original/PqDpPZwPEszATI5PMXBmAcKNZA.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/4Ip4WiAh5Rr0aJlyLm5xbnEbDJh.jpg">http://image.tmdb.org/t/p/original/4Ip4WiAh5Rr0aJlyLm5xbnEbDJh.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/qku5gyeGrB7y6k1SjWvDvOGB4Ho.jpg">http://image.tmdb.org/t/p/original/qku5gyeGrB7y6k1SjWvDvOGB4Ho.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/meQspJeM0BaoeElPPiOHOEoI4LY.jpg">http://image.tmdb.org/t/p/original/meQspJeM0BaoeElPPiOHOEoI4LY.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/o8Yw4NmRgTvcDCOZZaF93WhyNNS.jpg">http://image.tmdb.org/t/p/original/o8Yw4NmRgTvcDCOZZaF93WhyNNS.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/v06jCWcnaiPf8Z9mF2CYiSFjJE6.jpg">http://image.tmdb.org/t/p/original/v06jCWcnaiPf8Z9mF2CYiSFjJE6.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/iMBaxERRhkNqne8PF6d3po5lzHl.jpg">http://image.tmdb.org/t/p/original/iMBaxERRhkNqne8PF6d3po5lzHl.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/syuTAIL0f5Ndh78uSRHKWiD5uRz.jpg">http://image.tmdb.org/t/p/original/syuTAIL0f5Ndh78uSRHKWiD5uRz.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/3sUeNnycXvCCsHotjjMgGCngl7a.jpg">http://image.tmdb.org/t/p/original/3sUeNnycXvCCsHotjjMgGCngl7a.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/96ASIhpS9WjuHW74KTH4KjdfmGC.jpg">http://image.tmdb.org/t/p/original/96ASIhpS9WjuHW74KTH4KjdfmGC.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/smg8A2nIEFB27eSmaSbIGXDyoPA.jpg">http://image.tmdb.org/t/p/original/smg8A2nIEFB27eSmaSbIGXDyoPA.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/6UtnnBlZlqmllGdbctTfg0WtSTS.jpg">http://image.tmdb.org/t/p/original/6UtnnBlZlqmllGdbctTfg0WtSTS.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/2PlCeh0kXWCChrc3mRH2pkt0MLQ.jpg">http://image.tmdb.org/t/p/original/2PlCeh0kXWCChrc3mRH2pkt0MLQ.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/cSSZIkPQENCMIAttQKkYbyYxOv6.jpg">http://image.tmdb.org/t/p/original/cSSZIkPQENCMIAttQKkYbyYxOv6.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/bG8p7yk9lxwv9hlfWqmGbPe23bG.jpg">http://image.tmdb.org/t/p/original/bG8p7yk9lxwv9hlfWqmGbPe23bG.jpg</thumb>
    <thumb preview="http://image.tmdb.org/t/p/w342/mSPQWl516L7F1GcYtuVVAdQq5i5.jpg">http://image.tmdb.org/t/p/original/mSPQWl516L7F1GcYtuVVAdQq5i5.jpg</thumb>
    <fanart>
        <thumb preview="http://image.tmdb.org/t/p/w780/wBG4kHfhwm3bLwKUFNRByXXv4r2.jpg">http://image.tmdb.org/t/p/original/wBG4kHfhwm3bLwKUFNRByXXv4r2.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/uP2MIdOPzSkOeouhT7xu10TNEL2.jpg">http://image.tmdb.org/t/p/original/uP2MIdOPzSkOeouhT7xu10TNEL2.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/3l5CxSDIcWdtYne8m3BQDGOxFcl.jpg">http://image.tmdb.org/t/p/original/3l5CxSDIcWdtYne8m3BQDGOxFcl.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/rpEPlKeVdQkX7oVojXATvgHlSzP.jpg">http://image.tmdb.org/t/p/original/rpEPlKeVdQkX7oVojXATvgHlSzP.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/9bebtcFnkkjIHWodFPCbYkSx1mq.jpg">http://image.tmdb.org/t/p/original/9bebtcFnkkjIHWodFPCbYkSx1mq.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/52uYvs0JMlWjIcAvL0Pr8yZfrBm.jpg">http://image.tmdb.org/t/p/original/52uYvs0JMlWjIcAvL0Pr8yZfrBm.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/s3RmLACsT0sWKfiUkPvWHIcDnrt.jpg">http://image.tmdb.org/t/p/original/s3RmLACsT0sWKfiUkPvWHIcDnrt.jpg</thumb>
        <thumb preview="http://image.tmdb.org/t/p/w780/iDBZ7JsHbCKCYL3MUBjJctOWnTp.jpg">http://image.tmdb.org/t/p/original/iDBZ7JsHbCKCYL3MUBjJctOWnTp.jpg</thumb>
    </fanart>
    <actor>
        <name>Mike Myers</name>
        <role>Shrek (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/sa8MMxXZrHgQ85hTAP11WS4N3ik.jpg</thumb>
    </actor>
    <actor>
        <name>Eddie Murphy</name>
        <role>Donkey (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/bsi706zdqs0KAPdOsqz6AkLNcFF.jpg</thumb>
    </actor>
    <actor>
        <name>Cameron Diaz</name>
        <role>Princess Fiona (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/ahFkUN9Sm8oF1txUHE5JcJ95Ere.jpg</thumb>
    </actor>
    <actor>
        <name>John Lithgow</name>
        <role>Lord Farquaad (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/uquz3dZ0fs0lAK57lCXwxaslVkb.jpg</thumb>
    </actor>
    <actor>
        <name>Vincent Cassel</name>
        <role>Monsieur Hood (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/yTTyX7xziiMibm0nzcH5z6xxLLv.jpg</thumb>
    </actor>
    <actor>
        <name>Peter Dennis</name>
        <role>Ogre Hunter (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/9fNNPSTxuoVgsdJwQVmWUx9EDLT.jpg</thumb>
    </actor>
    <actor>
        <name>Clive Pearse</name>
        <thumb>http://image.tmdb.org/t/p/original/dO8RhoEjfRzdWfNARRo1XaFLQOm.jpg</thumb>
    </actor>
    <actor>
        <name>Jim Cummings</name>
        <role>Captain of Guards (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/i9frXvIJsGtoFikBEFVqE7uN8Bq.jpg</thumb>
    </actor>
    <actor>
        <name>Bobby Block</name>
        <role>Baby Bear (voice)</role>
    </actor>
    <actor>
        <name>Chris Miller</name>
        <role>Geppetto / Magic Mirror (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/3nwwLDbRaTQHp26cuDNw1KRgCZd.jpg</thumb>
    </actor>
    <actor>
        <name>Cody Cameron</name>
        <role>Pinocchio / Three Pigs (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/tEVQtTHkBPuqUzER8mvDyy6NaVO.jpg</thumb>
    </actor>
    <actor>
        <name>Kathleen Freeman</name>
        <role>Old Woman (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/heWbPEh1WTVS0fdv6QU61N9AuaX.jpg</thumb>
    </actor>
    <actor>
        <name>Conrad Vernon</name>
        <role>Gingerbread Man (voice)</role>
        <thumb>http://image.tmdb.org/t/p/original/kSyVrs8NtLoQhfBXFBhnTWzC7Vm.jpg</thumb>
    </actor>
    <fileinfo>
        <streamdetails>
            <video>
                <codec>h264</codec>
                <durationinseconds>5408</durationinseconds>
                <width>1920</width>
            </video>
            <audio>
                <codec>truehd</codec>
            </audio>
            <audio>
                <codec>ac3</codec>
            </audio>
            <audio>
                <codec>ac3</codec>
            </audio>
            <subtitle>
            </subtitle>
            <subtitle>
            </subtitle>
            <subtitle>
            </subtitle>
            <subtitle>
            </subtitle>
            <subtitle>
                <language></language>
                <file>Shrek.2001.1080p.srt</file>
            </subtitle>
        </streamdetails>
    </fileinfo>
</movie>
also please add Set field on main movie window (when editing) or a window next to metadata (when editing movie Smile )
  • 9
  • 10
  • 11(current)
  • 12
  • 13
  • 171
  • 2 Vote(s) - 5 Average
Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread52
