  • 30
  • 31
  • 32(current)
  • 33
  • 34
  • 176
WIP Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread
(2016-06-11, 16:52)DanCooper Wrote: You can not change the language and click rescrape in Edit dialog, you have to confirm the changes with Ok. The reason is that Rescrape ignore all changes and reload the information from database for a new scrape.
Maybe I am missing something, but this does not appear to work with the June 1 built of the alpha. I am changing after going to "edit" and then click "ok". When going back "edit", it is changed back to the previous language. The only thing working is going to "right-lick" and set the new language.
(2016-06-11, 16:52)DanCooper Wrote: Profiles are working very simple: create a new folder in .\Ember Media Manager\Profiles. You can copy single setting XMLs from Default folder if you want. All missing files will be created while first start.
That's very cool. So, this allows me to do exactly what I want? Basically two different Kodi installs with one being for my 2D movies and one for 3D?
Server: Asus Sabertooth Z77 | Intel Core i5 3.4 GHz | 16 GB DDR3 | 128 GB SSD, 82 TB (9 x 6 TB, 7 x 4 TB)
HTPC 1: Raspberry Pi 2 | HTPC 2: Raspberry Pi 2 | HTPC 3: Raspberry Pi
I am getting error when I updated my old version to this one.
Also if we do this pattern for renaming movies
$T {($Y)} $V
Output sample
The Avengers (2012) 3d\The Avengers.bluray
Should the word "3d" not be in capital?
ie. 3D
Yes it can be whatever you want, 2 different KODI, the same or just an test setup version of Ember
is there a way to avoid needing to pick a profile when startup ie Make it default.
Also there should be a menu item to switch profiles while inside the program?
(2016-06-12, 12:38)madmax2 Wrote: is there a way to avoid needing to pick a profile when startup ie Make it default.
In the Ember shortcut add "-profile default" (without quotes) to the end of the target
thanks.
Though it should be enabled by default inside the program
instead of needing to resort to parameter editing.
thanks.
... it's Alpha ...
any chance to add a filter for "Not Locked"? It would be great to see that, I typically lock once I have everything I want and filter those out would be nice.
Living Room: Vizio 65" 4K HDR/DV, Apple TV | Mancave: Panasonic 46" Plasma, FireTV | Bedroom: Panasonic 32" LCD, FireTV
NAS: unRAID 6.x (64TB + cache) | AZZA Helios 910 | ASRock Z68 Extreme4 | Intel Core i7-2600K Sandy Bridge Quad-Core 3.4GHz | Antec NEO ECO 520W | G.SKILL Ripjaws Series 16GB | Supermicro CSE-M35T-1B
(2016-06-16, 17:23)thrashmagazine Wrote: any chance to add a filter for "Not Locked"? It would be great to see that, I typically lock once I have everything I want and filter those out would be nice.
I think a better solutions is to add an "Invert" checkbox for all these filters. Good idea?
(2016-06-16, 18:20)DanCooper Wrote: I think a better solutions is to add an "Invert" checkbox for all these filters. Good idea?
I would agree!
4x R-Pi4b LibreELEC v10 | Aeon Nox: SiLVO | Flirc cases
Storage Synology DS411 | 4 x WD RED 6TB
Software MariaDB 10.4.19 | Filebot | Ember Media Manager
wiki (wiki) | First time user (wiki) | Debug_Log (wiki) | mysql (wiki) | artwork (wiki)
New Alpha 16 2016-06-18 is online!
New Kodi 16.0 "Jarvis" (and newer) <set> node is now supported. Ember can read the old and new format at any time. But you have to config which format do you want use for writing in NFO.
YAMJ compatible sets option has a new name and moved to "Settings => Movies => Scraper-Data => Collection". YAMJ ordering works now in Edit MovieSet dialog.
As always: check each settings, there are many new features and some settings has been changed!
Dan did you check out this http://forum.kodi.tv/showthread.php?tid=...pid2355245
(2016-06-18, 00:49)komplex Wrote: Dan did you check out this http://forum.kodi.tv/showthread.php?tid=...pid2355245
Bug Angry
I will check that today.
Should we report any bugs found, in this thread?
Cos I found two.
(2016-06-18, 15:38)madmax2 Wrote: Should we report any bugs found, in this thread?
Cos I found two.
As always. Bug Tracker is broken and should only be used for stable releases or feature requests.
  • 30
  • 31
  • 32(current)
  • 33
  • 34
  • 176
Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread2
