I remember at one point there was talk about maybe adding support for additional scrapers or using the different Kodi scrapers in Ember. Just wondering if this is still a possibility.
I'd love the ability to scrape anime in Ember using AniDB.net. Even better would be to do it with Scudlee's excellent AniDB.net Scraper Mod for Kodi. It scrapes the specials, credits, trailers, and all the other special files listed on AniDB.net.
I've had problems where scraping anime in Kodi would skip a series here and there. It is always so hard to track down the missing series and figure out why the scraper had trouble with it. Ember would solve that. I could instantly see which shows were missing info.
@Dan
can you please check that Rename feature still works... (latest alpha cannot rename files that are in network)
2016-07-17, 22:33
(This post was last modified: 2016-07-17, 22:41 by solamnic.)
@Dan
also when i try to remove a movies that has read only files - Ember Crashes....
also when i rename a movie Ember is not updated, i have to click on other movie then click back on the movie i rename to see that it was renamed...
Alpha 19 is online. Check first post for links.
@dan
have send you PM with problems with renamer with latest alpha 19
New 1.4.8.0 Alpha 20 is online.
Only a bug in renamer with IMDB ID has been fixed.
2016-07-21, 03:06
(This post was last modified: 2016-07-21, 03:28 by McButton.)
Updated to the Alpha 19. Seems like doing a general scrape now takes an hour to clear when it once took about 3 minutes for an added file. What did I break? I just installed over the old version (15)...but I'm sure something got messed. Ideas?
Edit: Just reinstalling fresh. I always kill something when I update.
