Hi, just a short question:
Is there any ETA for a new version of ember?
What will be new/changed in the upcoming version?
Hi again - I still have my outstanding TV library issue. At this point, how can I just delete that library and have it rescan the entire thing? I'd want to not impact the movies as they are fine. Thanks.
Hi all
I have been using ember 1.3.0.11 for years with xbmc 12.2, I have just updated to Kodi 17 and I am starting a new database and would like to know.
1. do I need to redo all my .nfo files with ember 1.4.8.0 before I import my movies ?
2. is there anything that ember 1.4.8.0 adds to the .nfo files that the old version did not to support more info for kodi 17 ?
3. is there anything I need to watch out for in the new ember over the old version
4. anything I missed out
5. oh is there any bugs I need to watch out for
thanks for any help
2017-02-11, 12:22
(This post was last modified: 2017-02-11, 18:04 by meridius.)
Just tired the new version and noticed that Ember does not scrape PCM audio files properly as it saves it as
<codec>PCM</codec>
kodi 17 saves it as
<codec>pcm_s16le</codec>
anyway to get this added
also I have Use Duration for runtime ticked and <m> but looking in the .nfo it says
<durationinseconds>0</durationinseconds> it should be durationinseconds>6449</durationinseconds> so I don't know why its not getting that data to
also the new ember creates <runtime>104</runtime> which is not right as it should be <runtime>107</runtime> as kodi and the old ember creates <runtime>107</runtime> and the movie run time is 1h and 47min which is 107 min so I don't know why the lates ember is creating 107 min
any help on that thanks
Using Ember's IMDB scraper to populate the trailer fields Ember will fill in from a couple of different sources, neither of which works when I try to play the trailer in Kodi (to be clear, I'm not downloading the trailer, just adding to the NFO). To properly scrape trailers I have to disable trailer scraping from IMDB and implement from TMDB. However, some movies only have trailers on IMDB. Is there a way for Kodi to interpret the URLs dropped into the NFOs for the IMDB trailers or am I stuck with either using TMDB only or downloading the trailers from IMDB so they can be played in Kodi?
