To my english speaking friends: I need the correct spelling for this options/settings:
Display Banner <= display or show? Means hide this image type in main windows or not
Display image dimensions <= display or show / dimensions or dimension or resolution
Display image name <= same same
Hi Dan,
Just to highlight you the following "issue" (maybe you are already aware of it).
In general, when saving the library from Kodi, the original .nfo files are overwritten. I have noticed that the format used in such .nfo files differs from the one used by EMM. In particular ratings are written in a different way so that if I reload the .nfo file in EMM these are just missing. In addition to that, some information that are available in the .nfo file generated by EMM (e.g. releasedate, id of TMDB, etc.) are just lost: maybe Kodi doesn't recognize them and when saving back the .nfo files, it just doesn't write them.
Do you think you can syncronize with the developers of Kodi to use a common format for the .nfo files so that such issues can be avoided?
Light IMDb Ratings Update - Keep updated the IMDb ratings for your movies and TV shows.
In case you found useful my work, feel free to offer me a cappuccino!
+1
in addition:
kodi (ATM) doesn't recognize "releasedate YY-MM-DD" only year ... it's a pity.
thanks
Hi is it possible somehow for Ember to change the file modified date to current time, since I have Plex and when adding a new video with old file date it doesn't show up as new video?
Hi again. I have updated to newest version but when I run
Ember Media Manager.exe -updatemovies -newauto -all
I doens't do what I want.
I want it to update library so new movies are recognized and scrape new movie.
It doesn't work.
In my old version this worked fine:
Ember Media Manager.exe" -newauto -all
Can you help please?
Alpga has changed the command line commands. Please check the pinned thread for Alpha commands.
