  • 129
  • 130
  • 131(current)
  • 132
  • 133
  • 174
WIP Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread
(2017-12-20, 17:54)DanCooper Wrote: Maybe IMDB will be reduced to "Rating and Top250 only" scraper
You should do this and add an OMDbAPI module if people want IMDB info they can get their own apikey
EDIT: IMDB Changes https://getsatisfaction.com/imdb/topics/...rence-view
In the last few days I have noticed that the IMDb scraper has stopped scraping a majority of information including cast and plot outline along with a few other fields. I saw something mentioned in the two posts before mine saying that they had changed their website again. Will there be any kind of solutions to this? If I have to get my own API key I am more than willing, I'm just curious as to what is going on because I don't follow the thread on a daily basis
I have also included a screenshot
(2017-12-22, 17:38)mark112887 Wrote: In the last few days I have noticed that the IMDb scraper has stopped scraping a majority of information including cast and plot outline along with a few other fields. I saw something mentioned in the two posts before mine saying that they had changed their website again. Will there be any kind of solutions to this? If I have to get my own API key I am more than willing, I'm just curious as to what is going on because I don't follow the thread on a daily basis
Anything unclear in Dans answer just a few posts before yours?
2681157 (post) and in an separate tread
325675 (thread)
I saw his post but not the thread thanks for pointing that out. I've just switched to tmdb for now
I'm unable to scrape the metadata of two of my movies. Is there anything I could try to make it work? MediaInfo does open them just fine.
(2017-12-19, 18:00)komplex Wrote:
(2017-12-19, 17:59)deh2k7 Wrote: Hi all,
I have been away for a while.  The last build I see at the beginning of the thread is from March.  Is there a newer build than that?
Thanks,
Dave
 316733 (thread)
Thanks Komplex!
Ember no longer saves any images other than poster and fanart.
Whilst scraping I can select a banner, logo, clearart, disc, etc however they never actually download?!
Any filename enabled for these Image types? Any hint in the log? Depending on the enabled file names its important that you have enabled "each movie is in a seperated folder" in your source settings.
German Ember Media Manager Support
Daily Builds - Link
Latest official Ember-MM version - Ember Media Manager 1.4.x
I'm trying to find duplicates so I've decided to export my movie list and load it into excel. When I do Tools > Export > Movies, the resulting XML would list some movies multiple times. I count each <ListTitle>xxxx</ListTitle> as one entry. In the gui, if I type in the movie title in the search bar, it only comes up once. But in the exported XML, the same movie comes up twice. I've ran 'Clean Database' and it didn't help.
I've to check the export function.
But you can search duplicates also in Ember based on the IMDB ID. There is a checkbox in the filter panel under the list.
Daily Builds - Link
(2017-12-27, 15:48)DanCooper Wrote: Any filename enabled for these Image types? Any hint in the log? Depending on the enabled file names its important that you have enabled "each movie is in a seperated folder" in your source settings.
 Mine also stopped scrapping all IMDB data except poster and fanart.  I only noticed it because the rating stopped being scrapped, but now that I look, none of the other stuff is scrapped either.
Same for me.
YOYIZDERZOMENEMOHOZEZAZEZDENDERIZHOZEZ
Same for me.
Dan already said that it needs to address the changes on imdb site. "combined" page has change to "reference" and all the tags and structure has changed...
Image Image
(2017-12-30, 03:33)bek1 Wrote:  Mine also stopped scrapping all IMDB data except poster and fanart.  I only noticed it because the rating stopped being scrapped, but now that I look, none of the other stuff is scrapped either.
Same for me.
Must have missed that. Smile
(2017-12-29, 18:24)DanCooper Wrote: But you can search duplicates also in Ember based on the IMDB ID. There is a checkbox in the filter panel under the list.
That is a much better option. Thanks.
On a different issue, I noticed that I after a removed some movies from a movie set, they still appear in the set on kodi after a library update. Then I read that kodi will only ignore the nfo file from existing movies and the only thing you can do is clear the database to make it read the nfo files again. Is this the only way? Kodi doesn't really make it easy to clear the database. Is EMM able to update the kodi database directly or through kodi? I have the kodi database on mysql?
  • 129
  • 130
  • 131(current)
  • 132
  • 133
  • 174
  • 2 Vote(s) - 5 Average
Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread52
