  • 163
  • 164
  • 165(current)
  • 166
  • 167
  • 174
WIP Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread
You have to "Refresh" the meta data to replace the codec info with your mapped codec. Then the logo should be showed.
German Ember Media Manager Support
Daily Builds - Link
Latest official Ember-MM version - Ember Media Manager 1.4.x
(2019-01-09, 12:09)DanCooper Wrote: You have to "Refresh" the meta data to replace the codec info with your mapped codec. Then the logo should be showed.
How do I refresh the meta data. I only scraped the show after the mapping.
Kodi v18.5 (AEON MQ 7 Leia Mod) running on Windows 10
or via context menu (Scrape -> Auto -> Only Metadata). But if you've changed the mapping before you've scraped than it already should be mapped...
Daily Builds - Link
Thanks, that's what I thought. Don't know what the problem is Huh
Regarding my first question, any thoughts?
Are you SURE you mapped it correctly?  It looks like there is a space before and after /
Not sure. If you look at the other mappings, they have spaces.
I will test it when I get home today.
Hi @DanCooper
Would it be possible for a future version of Ember to scrape the following rating tags for us & add them to the .nfo file?
Here are an example for one of my movies:
<ratings>
        <rating name="imdb" max="10" default="true">
            <value>7.4</value>
            <votes>479,914</votes>
        </rating>
        <rating name="metacritic" max="10">
            <value>6.3</value>
            <votes>35</votes>
        </rating>
        <rating name="themoviedb" max="10">
            <value>7.6</value>
            <votes>10,625</votes>
        </rating>
        <rating name="tomatometerallaudience" max="10">
            <value>8.0</value>
            <votes>1150028</votes>
        </rating>
        <rating name="tomatometerallcritics" max="10">
            <value>8.2</value>
            <votes>234</votes>
        </rating>
    </ratings>
    <rating>7.4</rating>
    <votes>4,79 ,914</votes>
    <userrating>0</userrating>
    <metascore>6.3</metascore>
@JanM201
The ratings node is already implemented for next release, user rating is already implemented in latest releases. I've to add a new setting to select a rating provider for the "old" rating and votes nodes and metascore. Is "metascore" the value from Metacritic? Why you written a "Double" value (6.3)? Metacritic normally use "Integer" values (from 0 to 100).
Daily Builds - Link
Hi @DanCooper
Not too sure. The example I've given was scraped by Media Companion. I needed to use that media manager to get all the
ratings so they would show up in my skin (Aeon MQ7 Leia Mod). I would prefer to use Ember, because the scraping process is so much
easier & quicker (Selection of Posters, Fanart & other art). I scrape every movie manually. Any idea when the new Ember would be released?
Thanks Rofl
Hi - any eta on beta or stable release Smile, the alpha builds have been sporadic at best!
ConvertToProperEnglish (please :-) ):
We have to limit the ammount of downloaded images to a useful value to prevent useless traffic on the image providers.
The limit for automatically downloaded Extrafanarts and Extrathumbs is 20.
Notes: Most skins can't show more than 4 Extrathumbs.
It's still possible to manually select as many as you want in the "Image Select" dialog.
Daily Builds - Link
It looks fine, could maybe change the wording a little
We have to limit the amount of images downloaded to a suitable value to prevent needless traffic on the image providers.
Hi guys.
I'm trying to scrape TV Series Doctor Who (2005) but EMM seems to be stuck on Scanning Meta Data.
The series has 170 episodes on 11 Series (and 1 Specials folder).
EMM has been Scanning Meta Data now for almost 2 hours with no changes.
Can anyone help?
(2019-02-16, 17:53)spinecho Wrote: Hi guys.
Can anyone help?
No matter, it's finished...seems it just takes absolutely AGES to scan 170 odd episodes!
@DanCooper long time no post ;-) any hope of stable beta release Smile
  • 163
  • 164
  • 165(current)
  • 166
  • 167
  • 174
  • 2 Vote(s) - 5 Average
Ember Media Manager 1.4.8.0 ALPHA - Discussion Thread52
