helta
Posting Freak
I'll say it again, not going to happen =)
The scenario is this:
You setup your Kodi library in a MySQL database, so that even your local Kodi install on your HD Station uses smb:// paths to play your content. You can then install Kodi at work, with the correct advancedsettings.xml, and any "changes" you make to your library will automatically be represented on your other local HD Station install.
My interpretation of what Oyvindo is asking for is the ability to use/control Kodi fully with a UI exactly like Kodi (whether Confluence or soon Estuary) but without using the TV that is connected to the device that is running Kodi.
If that isn't what he wants then it is something I would love. In effect a Kodi head to go with "headless" Kodi (something that is being worked upon). Then I could play music on Kodi without putting the TV on. Now the API using web interfaces and remote apps get so far, and several are very good in there own way, but none I have seen provide the full Kodi UI functionality, and none look like Confluence.
helta
Posting Freak
I'm really not trying to argue at all.
So what you are asking for is a web based client? That does everything that a full client does, but still plays whatever from the client attached to the tv?
jjd-uk
Team-Kodi Member
2016-03-04, 16:48
(This post was last modified: 2016-03-04, 16:52 by jjd-uk.)
helta is right 100% what you want is NEVER going to happen via a web client, the Kodi interface requires a native client to be able to provide the 3D graphics for the skins and that's simple not possible via a web browser. As has been said multiple times now, the ONLY way you'll going to be able to mange Kodi with the exact same experience as it appears to your your family in the other room is to use remote desktop software, so if you can't do that with your NAS then you need to run Kodi on a device that allows you to install a desktop OS which will allow you to connect via remote desktop.
Vidman
Senior Member
2016-03-04, 17:49
(This post was last modified: 2016-03-04, 17:52 by Vidman.)
Have you looked into emby server for your qnap?
From what I understand it will do exactly what you want to achieve.... Unless of course I am miss understanding you like everyone else
