808?
Senior Member
Waiting for the 15th of May!
Does anyone know if the Play 2S or the more basic version (Play 2 / Play S ?) will be able to stream TV over a network like the HDHomerun does (they being the ones who won't come up with a Homerun DVB-S box) ?
(2016-05-16, 00:22)arrbee99 Wrote: Does anyone know if the Play 2S or the more basic version (Play 2 / Play S ?) will be able to stream TV over a network like the HDHomerun does (they being the ones who won't come up with a Homerun DVB-S box) ?
Yep, a Play, Play2, or Play 2S can all act as network tuners for other devices on the network. It's not as turn-key as an HDHomeRun, but the setup for most tuners is very well documented. At least for the DVB ones. (US is a challenge due to crazy EPG/schedule issues.)
Sounds promising. Will have to try grovelling to the folks at Emby to see if they can write something to use one of these natively, like they do for the Homerun.
Can anyone here confirm the play 2s has all the TV tuners in it? C/t/t2/s/s2?
Will the WETEK Hub support HDR10?
10-bit yes, HDR no I believe.
[H]i-[d]eft [M]edia [K]een [V]ideosaurus
My HT
They said on Facebook: "WeTek Hub is just around the corner..."
Can't wait more!!!
