• 1(current)
  • 2
  • 77
WIP Windows 3D MVC Bluray test builds
These test builds could possibly be unstable. Proceed with caution and always backup (wiki) your settings!
What is this:
  • These are test builds for anyone who would like to help with testing the 3D MVC (mkv, 3D-BluRay) decoding.
  • Make sure you have the latest driver for your video card installed and the most recent DirectX version. See Microsoft website for more details
The main aim of this thread is to help identify issue related to the Stereoscopic 3D feature and 3D MVC decoding.
How to help:
Please include in your post:
  • Say if this was also an issue in previous builds or not.
  • A full debug log (wiki) posted on xbmclogs.com or pastebin.com
  • Possible crashlogs uploaded for download. Make sure you have the correct .pdb file placed in the install folder
  • The build date (in the download URL or in system info on Kodi). Specify which one you tried.
  • Details about your system (OS, hardware specs, videocard, driver etc)
  • Steps needed to reproduce the issue (play a movie, go to a file list, use an add-on, etc)
  • The more details, the better.
  • You may also post that everything is working as expected so we known current state of this development. In this case also provide full info.
Where to download:
Specific 3D MVC test builds are listed below. Other files in the "test-builds" directory are unrelated to this testing.
Builds will be updated on regular bases. Make sure you always try the most current one listed below before reporting problems.
Windows:
  • September 19
  • please also download the .pdb file here, rename it to Kodi.pdb and place it alongside the Kodi.exe inside the installation folder (usually C:\Program Files (x86)\Kodi). Re-download the correct file each time you are install another test build. This helps us to identify possible crashes.
  • For AMD/nVidia users: please download software implementation of MVC decoder libmfx32 and extract it to the installation folder (usually [/i]C:\Program Files (x86)\Kodi).
Example post
Quote:
  • Hardware: Windows 7 64bit, NVIDIA GT275, driver-version 340.52
  • Debug Log: pastebin.com/xxxxxxxxxxx
  • Crashlog: Dropbox lin
  • Description: Video problems while playing back MKVfiles.
  • Screenshots: Dropbox link
  • How to reproduce: Playing back a MKV video file. I have provide a sample file for download.
Any irrelevant post will be removed without notice!
Stereoscopic 3D rendering:
Stereoscopic 3D rendering is only enabled on systems that have all the components that are stereoscopic 3D-capable. These components include 3D-capable display hardware, graphics hardware, peripherals, and software applications.
System requirements:
1. Windows 8 and later.
2. WDDM 1.2 video driver. (To check version of driver please run dxgiag on your PC and look at [i]Driver Model at the Display section.)
3. DirectX 10 capable and higher video hardware.
4. 3D-capable display.
Also you need enable checkbox Stereo 3D settings for all supported displays in Screen Resolution control panel, as shown here:
Useful tools:
To check that your system is Stereo 3D capable you can install Stereo 3D test application from Microsoft Store and run it.
Changes:
April 13
Fixed:
  • Fixed ghosting issue
  • Now Kodi force switch to 23.976 fps before switching to stereo 3D mode.
  • Updated to the latest Krypton branch.
Removed:
  • Experimental: support of smooth playback was removed.
April 7
Fixed:
  • Fixed addvanced settings, <usedisplaycontrolhwstereo> and <forcemodechangebeforestereo> don't require <adjustrefreshrate> section anymore.
  • Fixed decoding on some hardware which doesn't support hw decoding.
  • Fixed num of internal buffers which causes decoding error in some cases.
  • Fixed a performance issue in decoder.
  • Fixed rendering video after resize Kodi window.
Added:
  • Experimental: support of smooth playback.
  • PR#9542 which solves issue with "ghosting" in some cases.
Known issues:
  • The latest Krypton may causes an error: python27.dll not found.
March 21
Fixed:
  • Fixed pixellation on some BluRays
  • Fixed crash when Kodi unable to switch to stereo 3D mode.
Added:
  • Advanced setting <usedisplaycontrolhwstereo> (default disabled). If enabled Kodi will switch on/off 3D mode on system level. This may help NVIDIA users and switching off stereo 3D mode in full screen window.
    <video>
      <usedisplaycontrolhwstereo>true</usedisplaycontrolhwstereo>
    </video>
  • Advanced setting <forcemodechangebeforestereo> (default disabled). If enabled Kodi will force switch to 1080p23 mode before stereo 3D mode. May helps on some devices.
    <video>
      <forcemodechangebeforestereo>true</forcemodechangebeforestereo>
    </video>
March 21
  • Forcing change resolution to 1080p23 before switching to stereoscopic 3D mode. This may fix an issue when switching to S3D mode is denied by driver.
  • Possible fix for switching back to monoscopic mode when use full screen window.
  • Now Kodi properly handle BluRays where exteded view is a left eye view.
  • Other fixes and improvements from Krypton branch.
Issues
  • none
Preferable Kodi Setting
Settings/Videos/Playback/Adjust Display Refresh Rate/On start / stop
Settings/Videos/Playback/Stereoscopic 3d movies/Preferred mode
Settings/Videos -Acceleration/Decode 3D stereo videos/Checked
Settings/Videos/Dics/Play Main Movie
Settings/System/Use a fullscreen window rather than true fullscreen/Unchecked
INTEL W/Intel Graphics drivers
3rd Generation Intel® Core processors
4th Generation Intel® Core processors
5th Generation Intel® Core processors
6th Generation Intel® Core processors(Support 4k@60hz from MINI Display Port)
Intel® Core M processors
Selected SKUs of Intel® Celeron processors with Intel HD Graphics (DN2820 Celeron with @woronczak trick)
INTEL HARDWARE (Like the NUC's) DOESN"T REQUIRE INTEL MEDIA SDK OR THE DLL PATCH
[Tested]
  • Intel NUC6i3SYH Kit with 6th Generation Intel Core i3 Processor @movie78 (Blurriness could be my display or the Graphic card)
  • Beelink BT3 ( Atom x5-Z8300 ),but HD audio it's only PCM @looun
  • Intel BOXDN2820FYKH0 DN2820FYKH0 Celeron N2820 @woronczak
  • Intel Core i5 4570S Haswell system (default Intel Graphics @wesk05
  • I3 6300 Processor Retail Box Skylake with ASRock Z170A-X1/3.1 Motherboard@dukester
  • Intel NUC D54250WYK@timstephens24
  • Intel Core i3-3225 with Intel HD4000 @afedchin
  • Intel Core i5-4570 with Intel HD4400 @afedchin
  • Intel Core i5-4570 with Intel HD4400 Laptop @hdmkv (Instruction and solution on how to get it working)
US BUYERS/List of places to buy Intel NUC.
Here is few NUCs list I found, hope all these are compatible and if anyone find a better cheap version, please let us Know.
ALL THE NUCs YOU NEED
Intel Next Unit of Computing 2.5-Inch Drive Option BOXNUC5I3RYH
Intel NUC Kit NUC6i5SYH BOXNUC6I5SYH Silver/Black
Intel NUC NUC5i5RYH with Intel Core i5 Processor and 2.5-Inch Drive Support
Intel NUC Kit NUC6i3SYH BOXNUC6I3SYH Silver/Black
Intel BOXD34010WYKH1 D34010WYKH1 i3-4010U DDR3L SODIMM NUC Kit With Power Cord
GIGABYTE GB-BXi3-5010
ALL INFORMATION ABOUT INTEL NUC
[Working]
  • NVidia GTX 750 Ti@stevious (first success with Nvidia Graphic Card)
  • Nvidia Geforce GT720 card@Karnis
[NOT Working] (this may changes in the latest builds)
  • AMD A8-3850 APU with Radeon™ HD Graphics
  • AMD FX-8350 Black Edition
  • AMD A6 3670K Black edition/AMD Radeon HD 6530D @Skank
Anyone who can try these test build can provide their input and findings so I can add to the list help other on what hardware to get.
Notes:
Most functions in Kodi is not working since this an early Krypton Kodi 17 Build
(2016-02-24, 21:48)afedchin Wrote:
(2016-02-24, 19:48)Nelbert Wrote: Intel HD 3000 integrated graphics.... supports 3D according to this
The error was related to not having a demuxer from memory. Will try to recreate when I get a chance later.
Yes it is, but the latest drivers supports Intel Media SDK v.1.7, but Kodi requires v1.8. You can download latest Intel Media SDK from intel.com site and Kodi will use software decoding, your CPU more what enough to decode mvc.
Installed 2014 R2.
Same error as before
Quote:2:00:21 T:10024 NOTICE: DVDPlayer: Opening: bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls
22:00:21 T:10024 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
22:00:21 T:9244 NOTICE: Creating InputStream
22:00:21 T:9244 NOTICE: CDVDFactoryInputStream::CreateInputStream - <f1> bluray://udf://smb%3a%2f%2fdiskstationa%2fHD%20Movies%2fAvatar%20(2009)%2fAvatar%20(2009)%203D%20Bluray.iso//BDMV/PLAYLIST/00000.mpls <f2> udf://smb://diskstationa/HD Movies/Avatar (2009)/Avatar (2009) 3D Bluray.iso/BDMV/STREAM/SSIF/00000.ssif <ssif> udf://smb%3a%2f%2fdiskstationa%2fHD%20Movies%2fAvatar%20(2009)%2fAvatar%20(2009)%203D%20Bluray.iso/BDMV/STREAM/SSIF
22:00:21 T:9244 NOTICE: Creating Demuxer
22:00:21 T:9244 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls
22:00:21 T:9244 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
22:00:21 T:9244 NOTICE: CDVDPlayer::OnExit()
22:00:21 T:10024 ERROR: Playlist Player: skipping unplayable item: 0, path [bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls]
22:00:22 T:10024 NOTICE: CDVDPlayer::CloseFile()
22:00:22 T:10024 NOTICE: DVDPlayer: waiting for threads to exit
22:00:22 T:10024 NOTICE: DVDPlayer: finished waiting
Does that help? Previously no issue on Isengard (albeit Kodi defaulted to playing in 2d). It plays fine using VCD and PowerDVD on my main HTPC.
(2016-02-25, 00:05)Nelbert Wrote: Installed 2014 R2.
Install latest Intel Media SDK (IIRC the latest is 2016.01)
Newest sdk won't install for me.... Only compatible with generation after my CPU.... Any other method? Is there 2015 version?
Try download this https://www.dropbox.com/s/xka0cd3oz79bzf...v1.7z?dl=0 and extract to Kodi directory.
(2016-02-26, 16:29)afedchin Wrote: Try download this https://www.dropbox.com/s/xka0cd3oz79bzf...v1.7z?dl=0 and extract to Kodi directory.
tried that. still no joy
Quote:17:10:23 T:3752 NOTICE: DVDPlayer: Opening: bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls
17:10:23 T:3752 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
17:10:23 T:6128 NOTICE: Creating InputStream
17:10:23 T:6128 NOTICE: CDVDFactoryInputStream::CreateInputStream - <f1> bluray://udf://smb%3a%2f%2fdiskstationa%2fHD%20Movies%2fAvatar%20(2009)%2fAvatar%20(2009)%203D%20Bluray.iso//BDMV/PLAYLIST/00000.mpls <f2> udf://smb://diskstationa/HD Movies/Avatar (2009)/Avatar (2009) 3D Bluray.iso/BDMV/STREAM/SSIF/00000.ssif <ssif> udf://smb%3a%2f%2fdiskstationa%2fHD%20Movies%2fAvatar%20(2009)%2fAvatar%20(2009)%203D%20Bluray.iso/BDMV/STREAM/SSIF
17:10:23 T:6128 NOTICE: Creating Demuxer
17:10:23 T:6128 ERROR: CDVDDemuxFFmpeg::Open - error probing input format, bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls
17:10:23 T:6128 ERROR: CDVDPlayer::OpenDemuxStream - Error creating demuxer
17:10:23 T:6128 NOTICE: CDVDPlayer::OnExit()
17:10:23 T:3752 ERROR: Playlist Player: skipping unplayable item: 0, path [bluray://udf%3a%2f%2fsmb%253a%252f%252fdiskstationa%252fHD%2520Movies%252fAvatar%2520(2009)%252fAvatar%2520(2009)%25203D%2520Bluray.iso%2f/BDMV/PLAYLIST/00000.mpls]
17:10:23 T:3752 NOTICE: CDVDPlayer::CloseFile()
17:10:23 T:3752 NOTICE: DVDPlayer: waiting for threads to exit
17:10:23 T:3752 NOTICE: DVDPlayer: finished waiting
Any thoughts?
I have no idea.
You could try to mount the iso locally to rule out fs issues
Ok I can report some scenarios and the results.
Playing ISO directly in kodi - not working for me
Mounting iso and hitting play - not working
Navigating to the bdmv manually - not working
Navigating to the playlist manually - plays in 2D and no option to switch to 3D (uses h264 decoder not mvc)
Navigating to the ssif manually - working*
*the audio pass through although working fine reports 0 channels on the codec info (receiver picks up all channels fine. The processor is really struggling to play it and there is obvious stuttering and missed frames however these don't seem to be reported back to Kodi by the mvc decoder. The mvc decoder is still used if you select monoscopic / 2D option (which would be fine if the processor was up to the task I suppose.
The high CPU usage would seem to indicate the hardware acceleration feature isn't being used I assume?
1. In next version 3dbd will work properly.
2. Decoder cannot be changed on the fly when stereo mode was changed. Decoder can be disabled in the Settings -> Video -> Acceleration.
3. Yes, high CPU usage indicates software decoding.
This will only ever be an intel solution, I assume? (Or will the software decoding work with an AMD CPU?)
Looking for an excuse to upgrade my main HTPC anyway!
I wonder that too, i have an amd A6, wonderif thats powerful enough
(2016-02-27, 11:16)Nelbert Wrote: This will only ever be an intel solution, I assume? (Or will the software decoding work with an AMD CPU?)
Yes, AMD drivers doesn't support Intel MSDK, so on ADM GPU software decoding will work.
(2016-02-27, 11:43)Skank Wrote: I wonder that too, i have an amd A6, wonderif thats powerful enough
I didn't test, but I think Core-i3 or similar from AMD should be enough for softweare decoding MVC.
my notebook has an i5 with 2,4 GHz and a legacy AMD HD GPU and it worked for me. CPU was maxed out ofc
i5 has it's own gpu. but it requires a connected display to use hardware decoding.
  • 1(current)
  • 2
  • 77
Windows 3D MVC Bluray test builds5
