2016-04-16, 15:49
The url is weird looking, I looked twice when posting it too. I should note that I noticed no difference between official drivers or the last 2 betas. I saw this beta addressed some playback things so I installed it.
(2016-04-16, 15:23)hdmkv Wrote: That link isn't complete... can you re-post so I can add it to spreadsheet in post #1? Also, @dukester, yours is N2820 right, and @Skank's N2830? Guess latter is a h/w rev by Intel. @Skank, which graphics/driver version?
(2016-04-16, 19:35)timstephens24 Wrote: I don't have any issues with the beta drivers, old drivers, or the most recent driver.
@hdmkv, you can add me to the D54250WYK list as working. I think one thing to note if possible would also be 3D type (passive or active - maybe just go with a TV category?) since active worked great for me, but passive I saw blurriness and other issues that have been fixed (or is about to be fixed).
(2016-04-17, 13:55)timstephens24 Wrote: I had a lot of 'ghosting' issues after I switched my TV's, so maybe it's just seeing different issues since the display type is different. It was a very noticeable difference on animated films, and the test file that has the turtles in the ocean really displayed the issue well.
It was definitely noticeable if I put in the 3D Blu-Ray and then switch back to my NUC. That issue's been fixed though, so maybe it's now a non-issue? Wish I had better answers for you as to the specifics, because I thought that same as you.
(2016-04-17, 14:34)dukester Wrote:(2016-04-17, 13:55)timstephens24 Wrote: I had a lot of 'ghosting' issues after I switched my TV's, so maybe it's just seeing different issues since the display type is different. It was a very noticeable difference on animated films, and the test file that has the turtles in the ocean really displayed the issue well.
You have a pioneer vsx 1130 k?
(2016-04-17, 14:46)noggin Wrote:(2016-04-17, 13:55)timstephens24 Wrote: I had a lot of 'ghosting' issues after I switched my TV's, so maybe it's just seeing different issues since the display type is different. It was a very noticeable difference on animated films, and the test file that has the turtles in the ocean really displayed the issue well.
My Passive UHD display is pretty critical with regard to viewing height. If you are not square on to the display you get crosstalk.
(2016-04-17, 14:55)Bladerunner1962 Wrote:(2016-04-17, 14:34)dukester Wrote:(2016-04-17, 13:55)timstephens24 Wrote: I had a lot of 'ghosting' issues after I switched my TV's, so maybe it's just seeing different issues since the display type is different. It was a very noticeable difference on animated films, and the test file that has the turtles in the ocean really displayed the issue well.
I have a general question. I also run Kodi with a Intel Nuc (5i5RYK).
Do you output "real" 3D via Kodi 15 or 16? On the end MVC 3D?
Or do you use the new Kodi 17 under Windows 10?
(2016-04-16, 19:35)timstephens24 Wrote: @hdmkv, you can add me to the D54250WYK list as working.D54250WYK is already on the spreadsheet. I added you as another verified user, under 'Comments' column.
(2016-04-17, 10:30)Skank Wrote: Yes i got th dn2820 but with 2830 proc (it is sold as dn2820)So, it has the same Intel NUC DN2820FYKH model # even though its a 2830 CPU?
Its easy to get one.. As you can ask for a unit that has an SA number ending on 103 or above
(2016-04-17, 17:00)hdmkv Wrote:(2016-04-16, 19:35)timstephens24 Wrote: @hdmkv, you can add me to the D54250WYK list as working.D54250WYK is already on the spreadsheet. I added you as another verified user, under 'Comments' column.
