2016-10-02, 01:25
(This post was last modified: 2016-10-02, 10:07 by nifedipin.)
I'm using the september bulid on a Dell micro 3050 with windows 8.1 pro[just purchassed].No need to hunt for drivers!Works allnost instantly.My receiver is Pioneer VSX528.
First I didn't had the UP/UNDER option in my tv.Switched to 59p[from 60i] and my tv works like it should again.
Another issue: I always had a dificult "hand-shaking" after frame switching....so I disabled frame switching[sett NEVER].
My 3d bd isos are working anyway,3d mkvs are working too.Audio passthrough is working as it should."Hand-shaking" issue is gone!
I'm just lucky...I think,
N
Dell micro 3050,toshiba encore wt8-a-102,Belink MXIII,DidUbuy S95 Dragon Pro,Minix Neo 8H plus,Tronsmart mk908II
3D BR Isos with HI-RES. passthrough are working on my Belink MXIII[minix U1 ported rom] too.Player:SPMC 16.4.2.
Using Didubuy S95 Dragon[stock rom]:3D BR Isos working,but NO HI-RES passthrough[only plain ac3 and dts audio].Actualy I disabled dts 'cause this one has "glitches" every 8 secs.The player is SPMC 16.4.2.
No 3d Iso and no HI-Res passthrough using Minix 8H-Plus and/or Tronsmart MK908II[both with Finless Bob roms].
I hope this helped,
N
2016-10-06, 05:31
(This post was last modified: 2016-10-06, 05:32 by movie78.)
Was having too much issue with my Intel D34010WYK NUC,so i bought a new DN2820 and lucky it happens to be N2830 and i guess the 2830 is latest model of the DN2820.
Hope i have less issue with this model
MY CURRENT MEDIA PLAYER |
MY HOME THEATER
MINIX NEO U22-XJ COREELEC v19 MATRIX | EGREAT A10 | NVIDIA SHIELD | LG 75 NANO90 DV/HDR+ | Sony 43 Android TV HDR
XBOX SERIES X | PS4 PRO 4K | JBL 9.1 System 5.1.4 DTS:X/ATMOS
Really? What kind of problems?
My D34010 is great and much better than my DN2820 which wasn't powerful enough. The 2830 is supposed to be faster than the 2820 so you should be fine.
Box 1: ODroid N2+ 4GB
Box 2: Intel NUC D34010WYK (Windows afedchin's Krypton MVC Build)
Box 3: Vero 4K
RIP schimi2k | I miss you buddy :(
Is possible to install Kodi 16.1 MVC support?
I think she was before for download, but can not find the link!
I would like to install Aeon MQ 7 skin and it is only to Kodi 16.
