Correct.
3D MKV does not need libbluray. But it's needed for proper ISO support.
It looks like some users do not need ISO support.
Sam
Only issue with MKV is Dolby TrueHD & ATMOS in that if you ever need to go back to an ISO, if the core Dolby Digital track isn't already present, you'll need to use EAC3to create a THD+AC3 for tsMuxeR.
2018-05-14, 22:08
(This post was last modified: 2018-05-14, 22:09 by hdmkv.)
From the disc, it can. From MVC MKV file, it can’t if THD+ac3 isn’t present.
Haven't had a chance to do extensive testing, but with windows 10, a dvi to hdmi cable, and the mvc version of kodi, 3d mvc files are playing in 3d on the Asrock Q2900-itx board.
Krobar
Senior Member
A quick note for Nvidia / Software decode users; you might want to use the lib file from the newer Intel Media SDK. My NVidia setup is suffering general issues with 24P but the newer file from the 2018 R1 SDK actually started 3D playback for me at least.
seems the link for the latest build to be dead.
Is there another to download the latest build?
thanx in advance
Sorry, no longer have any Kodi MVC builds. Sold my NUC. If someone can upload it, I'll update post #1.
So what you using these days?
